The Samsung Galaxy Note 5 Thread
tkl23786
Sorry, other than wiping data and bloat, what does changing the code do or help?
Changing the code will change the firmware in the phone.
Basically, XSP is the "unmodified, original" firmware released my Samsung. Local Telco will modify the firmware and add their Telco-related apps/bloatware. These Telco-modified firmware will end with SIN/MM1/STH, depending on the Telco.
When ever Samsung pushes out new firmware, the XSP will receive it first. Those on SIN/MM1/STH will have to wait until the Telco modify it and push out to the consumers. So, occasionally, you can read on the forums that some people will receive OTA firmware update faster than others while others have to wait for a long time before they receive their OTA firmware update. This is due to the code used in the phone.
kero89
anyway to back up every data before changing to csc?
Root yes.
No root? Some of the app data can try using carbon app. Other data like sms call log gotta use apps like sms backup& restore. The phone data just copy it wholesale to your pc.
tkl23786
You can use Samsung's Smart Switch app.
Compatible with Android 4.4 and above, as well as iOS.
They have a mobile and a PC version.
Personally, I have used both mobile and PC versions.
The PC version is able to copy your WhatsApp data to your new phone (and you can also choose what files/folder/data to copy over)
You do not really need any other dedicated apps or programs to transfer data and files from old phone to new phone.
To add on: I copied almost 10GB of data from my Note 3 to Note 5 using the Smart Switch PC version
Sadist4life
SUjyz-YGi3wHzVABlWKnAGMT05lcGrnkfllxOudUWha9jBH0j8otoL-mtZYI0v3zgMNdC7H417SspB4=w1896-h835-rw
There's no patch notes for the recent software update.
Adolez
Hey guys, can you share what are first things you all did when you got your phone?
Factory reset, etc etc?
Wanna start on a clean slate.
bonnybear
hand writing mode in keyboard
hallo peers,
i do nid some help over with my note 5 keyboard.
normally there is a "T" icon on the left of the spacebar but this time round i could not find the T icon for handwriting. anybody can help me how to find back the T icon?
i know there is another way is by using the S Pen which hover over the text there is a T icon shown. is there any other way to call out the T on the keyboard like b4?
many thanks in advance.
Alexz_Hong
hallo peers,
If you're talking about the Samsung default keyboard, try tapping and holding the current icon beside the space bar. Then select back the "T" icon?
b_ongzhenyu
Hi, may I know what is these 2 arrows ? can it be removed? my mum's s5 suddenly also have and every time cannot call out our receive calls unless reboot. my s5 doesn't have until I change to n5. mine doesn't have any problems. I'm on m1 while my mum is on starhub.
Sent from Samsung SM-N920I using GAGT
