The Samsung Galaxy Note 5 Thread
nuscape
Since the latest firmware update did anyone notice that whenever the app picker pop up (open with ... and show u the available apps) it will no longer show the 'just once' and 'always' button. It will still give you the selection of apps you want to choose and once you tab the app then it will be set as 'always' for the next time.
It seems now I can no longer choose 'just once' option anymore.
So if I want to change it I have to go to settings and clear the default.
Anyone else experiencing the same?
Simple test is probably to try open a PDF file.
Sent from Samsung SM-N920I using GAGT
Anyone?
skaade
out of frustration due to the "sleeping beauty", I decided to do a clean wipe and reinstalled all my apps and data. a day passed and yet to get any sleeping beauties.
for those still experiencing it, may consider doing a full wipe and restore everything. so far working good.
I'm gonna wipe this weekend when I have the time. I feel like the battery life is bad but probably cos I loaded up tons of apps.
Gonna debloat it as well as per xda instructions
Sent from my cat messengers using GAGT
redtush
Can I ask those who recontract Note 5 with SINGTEL at comex..... did your phone come with any freebies? (like wireless charger, etc)
I recontracted by calling 1688, and forgot to check this point with the CSO. Just received by new note 5 in box but without any free stuff... so just checking in in case singtel act blur....
cj9404
saw lots of people taking about sleeping beauty here, can anyone share with me what is this issue about?
try to google it but can't find the answer.
Thanks.
Alexz_Hong
i have never seen those options on my note 5 ever. i just thought its their new way of dealing with the apps handling.
Same, i've not seen those option before. Once you select an app to open a file with, it sticks to that. A little annoying. Sometimes i just want to open the PDF to see only, but then when i want to fill in PDF forms and want to select "write on PDF", have to go clear default apps first. -_-
benny888
Thanks.
Sleep of death ? Basically phone stuck at black screen n unresponsive to even home button or power button
For me I had never faced such an issue yet on my N5 ( got it more than 2 weeks ago )
renfred89
Just wondering if clearing the cache from recovery menu helps?
I do have such issue once in a while on my note 4.. hopefully note 5 would get this issue ironed out..
benny888
Don't you have "Always use this application" right at bottom of all the recommended app list
Just don't select this option
renfred89
Wah, perhaps it's really the way it's designed to be. Come people feedback feedback.. :D
kero89
Do you have that option on your Note 5?
It will not have, but once you selected that app, it will always open with that App. Invisible "always use".
Gotta go to settings ->Applications -> Default applications to clear if want to open with some other app :o
renfred89
The wireless charging is faster than before
But will it get heated up?
Wireless charging is never as power efficient as wired charging due to the physical properties. You might expect a certain level of heat but that shouldn't be hotter than wired charging..
