Air purifier?
chuanz
Aiyo.. Didn't know need to wait one week. Hope will be faster. The plug is the same?
You can always donate one to your kids childcare centre. ��
From Qoo10 Daiso or GoniGlobal seller? Those are from Korea and would take about a week.
Plug is 2-pin but is thicker than our 2-pin, like European 2-pin.
- can force in
- get a 3-pin plug and cut wire + replace
- get those few dollars simple adapter
universal-power-adapter-2-pin-to-malaysia-uk-3-pin-emlabz-store-1501-09-Emlabz_Store@13.jpg
Denierx
- can force in
Any difference getting from either Daiso or GoniGlobal?
ralliart12
Just curious: when we sleep in air-conditioned room (not the office air-con type), are we essentially breathing in recycled air for that 8-9hours, i.e. no "new" air is introduced into our room?
consigliere
Just realized that the Sharp FUY30E is not HEPA filter?
Got any recommendations for air purifiers with HEPA filters that can cover 25m square (Budget below $200).
Thank you!
ANyone know where to buy 3rd party HEPA filter for Sharp FUY30E?
laeticia
My Air purifer is a Panasonic nanoe model (F-PMF35A) without Hepa filter.
Do you think it will make a difference if I buy the 3M filtrate and tie a piece over the existing filter? Using both AP and ac and I swear I can still smell smoke in my room :(
swastikas
Tks all for the recommendation.
Hooted a ax40 late last night for my living room
Funny last night q10 flash sale was 24X, now back to 26X.
Bought extra filter $78. All in include qexpress delivery is about 340.
Hope it come fast while i hang on to my Nap501
obsession
CADR of samsung AX40
Hi,
what's the CADR of this samsung AX40?
Can't seem to find it as a comparison to other brands.
Denierx
Same here! bought during the flash sale. Same price as you
wongminmin
The theory of the air-con is recycle the room air and cool it with the cooling coil.Your room is not actually air seal tight, air are exchanged through those leaks.
And for those who are using air purifier, keep your window/door closed for the best effect of clean filtered air.
wongminmin
don't worry about the price offer, they alway on/off the offer either by daily or weekly.
AX40H5000GMD now offer again @ 243.90 until 1000.
AX40H5000GMD look good and energy saving but HEPA filter replacement expensive. :(
chuanz
guys wanna check with u is amway good?
Amway ATMOSPHERE? Yes, it works, but jin sexpensive neh... like 2k+ per machine.
CADR converted to m3/hr
Wishper: 84
Low: 168
Medium: 252
High: 342
Turbo: 426
For me, personally I'd prefer multiple smaller machines for ease of repositioning and can spread out over the whole house.
Samsung AX40 (Qoo10)/AX41 (local equivalent)
LG LA-Q379 (Qoo10)/LG PS-R459 (local equivalent)
