Guys, where to find the daiso that is selling the samsung AX40? Thanks for sharing.
i didn't find the local set version price...but for this ax40 usual price is $300+What is the ax40 usual price
Any price increase now
Does the ax40 come with a filter installed or do I have to select the filter option.
@chows99 the daiso they are referring to is a shop on qoo10
Pardon my ignorance, anyone can share why is Samsung AX40 so popular?
i think ax40 so popular maybe due to this thread recommendation and haze worsen.
For me, i think it is
-Cheap
-High performance CADR 305
-Energy saving
-Quiet
tbh, most of them i see with this budget, perform less than CADR 200.
got warranty from sellersThe only bane is no warranty since buying from Korea?
for me, i just heckcare the warranty.....mailing back to korea is another cost. give and take loh.....local retail sellers sell ap to us like carrot cake.
Guys where can I buy ax40 in retail store? Buying on qoo need wait many days?
so can go taobao order the replacement HEPA for my model FU-Y30E... and ownself cut as I cant find original ones at Taobao... getting it here will be expensive...
any good brand will be good?
should I get H10 or higher rating and will it affect the airflow?![]()
Trust me, happened to me before, and TB seller is not Amazon freeship/CS.Bro WRX, can check hir if I order the replacement HEPA from taobao... The size you give can we still put in the deodorizer part ? Or does the tabao seller custom the charcoal part?
http://list.qoo10.sg/item/SUPER-TIMESALE-SAMSUNG-NEW-AX40H5000GMD/415159815?selectedOptions=;
Anyway that guy sold more than 100 set just today only
From $243.90 > $244.90 > $269 > $254.90
For people using SHarp FU-Y30E, the China model is FZ-Y180SFS
Taobao keyword FZ-Y180
Above information is courtesy from bro WussRedXLi.
Get from this seller, excellent service and extremely responsive ALWW replies. Excellent packing, so that you do not get a flattened or HEPA with holes.Trust me, happened to me before, and TB seller is not Amazon freeship/CS.
https://shop100284682.world.taobao....a.7700846.0.0.2yXHrR&user_number_id=812256264
Tell him you want the Sharp 180 机 HEPA.
Original is 30mm. You can ALWW and tell him to customse to 35mm depth.
30mm has very slight airflow drop. But it's basically H10 -> H11.5 upgrade, so no worries.
Pay 10% more and get 35mm depth. He can customise to 45mm as well, not sure if the FU-Z31 or your model can take it or not. But don't waste the money, 35mm is sufficient. Those who are anal and have budget, then maybe go 45mm depth.
The sides, just stuff up with some plastic wrapping paper that came with the HEPA or tissue paper, prevent bypass.
You will be in good hands, the stuff works. Measured before, at outlet, in-room performance etc. No worries.
