iOS 9 Discussions
ragnarok95
Senior Moderator
Senior Moderator
Installed. So far so good. Just hate the 6 character security input as compare to 4 in the previous OS.
Did a reset + restart and everything runs very smoothly after that.
ForumRider
Did you have a change of the security code? Mine is still using 4 character security code..
arcturuz
i'm still using 4 char security code
but this ios9.0 is really laggy on ip6+
ragnarok95
Senior Moderator
Senior Moderator
It shouldn't be laggy...on a ip6+. Did you do a reset? Mine was laggy too until a reset was perform and i hardly see any lag now.
Eightfold
settings -- passcode -- change passcode -- passcode options -- use 4 digit
for users updating from exisiting 4 digit, by default will be 4 digit still
ragnarok95
Senior Moderator
Senior Moderator
Didnt know that!! Thanks for the SIC!
Underdog
You mean should do a reset -> reset all setting?
layzibum22
Using for over a day. So far so good. Cos I'm like maxing out my 128gb space, the overall user experience is less choppy than iOS 8. Everything seems to show a somehow smoother use. It's subtle, but it can be felt.
jason910
Been trying to update since am, kept encountering the Software Update Failed message. Reset my network settings, my device still cannot. zzzz
layzibum22
is there a need to do a reset?
I always download and install.. that's it.
I feel during update the phone somewhat goes through a "reset"
I would only do reset all settings if really I feel need to. Quite ley chey to lose all wifi hot spot settings.
layzibum22
iTunes or OTA? Have you tried both?
I hope you have backed up also.
