The Samsung Galaxy Note 5 Thread
savage
Just completed factory reset. going to let it sit for 1 hour after charging to 100%. See how much I lose in 1 hour without installing anything else other than built in stuff. Didn't even disable s-voice. LOL~
omg... just checked the 1hr point... 1hr of standby took out 4% of the battery. WTF man...
all my older phones only used 1% for 7 hrs! something wrong...
human_shieldz
Did you clear the cache? Hmmm, one thing maybe also your cell signal. Maybe working OT to get signal. You go airplane mode see if it's same also or not. Cos now i suspect even if you bring to SSC also they will reinstall your OS only at 1st.
cptow1
when i am typing on the whatsapp keyboard fast....the screen will always freeze for a few seconds....after i reset the hp.....problem still remains.
Anyone encountered?
savage
actually i did go airplane mode overnight liao. and confirmed it's got to do with network.
because 5 hours, drop 1%... so either something is constantly poking the internet. or like you said, I have very bad reception... but never had this issue with other phones... unless this samsung unit the antenna is very lousy...
Now I'm trying to put it in 3G only. so now I get a full bar of reception. see if it helps.
kEvinErd
If its on airplane mode, then it can't be the internet or signal reception strength..
gintokichung
Hi guys im one of the users that has the sleep wake issue.. however about a day ago instead of doing a restore to factory settings... i went intk the "clear cache partition" mode to clear the conflicting cache system files of note 5 and it solved my problem.. you guys can google it and try it to see if it works for you guys.
savage
actually what I meant is. I did a test with airplane mode on.
5 hours with airplane mode on, drop 1% in 5 hours.
now I tried again changing LTE connection to 3G in order to get full bar signal
1 hour drop 1% with me using it very lightly receiving and reading sms.
So it really seems like its my signal strength that is causing the problem... I will monitor somemore... thanks for bringing up the fact that my signal was bad. I didn't pay attention to it cos I kept focusing on the fact that i'm on WIFI.
RobVanDam
Anyone else used this method and can work CONSISTENTLY.
Did try it before but the problem still comes back .... how often you have to clear the cache then ?? :s22:
human_shieldz
Samsung almost took the blame for your telco lol
human_shieldz
Eh wanna ask ah. If press home button the screen come on in the lock screen but freeze there and i can't do anything except press power button to put it into standby again then press the home button and can work.
Is this considered sleeping beauty issue? Or is it Cinderella issue.
Foress
what you mean? Launcher swipe left has the silly Flipboard thing. you have to remove it .
THen after that I think can swipe unlimited? I can't remember.
I don't use the stock launcher. I installed Apex. confirm can scroll until you song.
i removed the flipboard thing, still cannot swipe left :/ any idea how i can re-enable unlimited scrolling on touchwiz?
seller4
The unlimited scrolling feature has been removed in the new Touchwiz since Galaxy S6 and S6 edge time.
Only way to have unlimited scrolling is to use another launcher or a Non-Samsung, hacked version of Touchwiz.
