Air purifier?
kimsim
Suspended
This one the best and most expensive....king of AP!
https://www.youtube.com/watch?v=cwMv1J0-JBQ&feature=youtu.be
Amway? Not really is the best AP, just the brand name more powerful than others, Honeywell, Sharp high end also compatible with Amway AP.
Last time got one Amway seller let us tried for few days, the noise quite bad than sharp, also front panel easily cracked too.
For me of without humidifier function for the rest all are good.
bunn85
Hi, I understand that if I purchase 2 sets of the AX40 from Qoo10, gst is chargeable because more than $400. The solution is to split it into 2 separate transactions.
However, if seller decides to ship both units under 1 shipment, will gst be incurred as well?
Thank you very much.
Asakura
happen to me before
both items arrived at custom same time
so i kena gst
Asakura
Amway ATMOSPHERE? Yes, it works, but jin sexpensive neh... like 2k+ per machine.
CADR converted to m3/hr
Wishper: 84
Low: 168
Medium: 252
High: 342
Turbo: 426
For me, personally I'd prefer multiple smaller machines for ease of repositioning and can spread out over the whole house.
Samsung AX40 (Qoo10)/AX41 (local equivalent)
LG LA-Q379 (Qoo10)/LG PS-R459 (local equivalent)
as per chuanz comments.
is like iqair, i prefer having a few units in the house than only 1 unit
linusz
Info bookmarked
WussRedXLi
Did a 3M Filtrete (bought from Taobao version) test during a hazy day.
155 ug/m3 dropped to about 30 ug/m3 and maxed out there. Can't drop below that due to external loading. My windows and doors all locked already, and windows have gap sealing (strong winds do not cause howling)
2008h switched on air purifier, check out how fast it drops.
Airconditioning would fare much worse.,
