iOS 9 Ad Blocker
Nitrile
LOLOLOL
after spending almost 10 bucks on adblockers (after Peace refunded me), i found the best and fastest ad blocker, and it's FREE!!!
Look for Adblock Fast. :s13:
eurofunk
they shld just create a function in safari to manually input the url/domain to block...
Zapper1819
ya lor, nothing is really free in the world
But still thanks for your SIC! :)
If going to face things like whitelist in crystal app, then might as well use those free blocker. The main thing is to block those ads that keep linking me to the App Store.
lordleslie
admop must on all the features?
they have a lot of blockers like ads, arabic blocker, chinese blocker, etc
punggolkid
I just might have found a problem with purify. It seems to have been burning battery while using safari. Switching it off helped. I'm going to monitor over the next few days. If anyone experiences the same, do tell. Or post in the battery life thread.
dawntime
referencing from your post in the other thread.
only mac rumors webpage causes it or just any other webpages inclusive?
will try and report back hehe
dker333
Just tried purify, found it only blocks ads in safari, but other in app ads still showing.
What's the best blocker for ads in apps?
I'm using weblock (https://itunes.apple.com/sg/app/weblock-adblock-for-apps-websites/id558818638?mt=8) which blocks all ads inside apps. Filtering takes place right on your device itself and the app DOES NOT act as a proxy server or VPN for your traffic. Works by re-directing traffic from ad networks to google's DNS servers instead of your device. Google's DNS servers return a NULL result, hence the ads do not show up at all.
Only drawback is that it only works when connected to wifi. But combine it with the new safari content blocker and you will not see any ads 90% of the time! :s12::s12:
spidercyj
What about Google ads?
swathe
Apple's strategy is to force sites to implement apps. This way, Apple get the ads and appstore revenue.
punggolkid
So far my 24 hrs usage of the battery includes a whopping 45% on safari. Even my games that I play are more battery efficient (a flight Sim called Infinite Flight runs cooler than safari with purify enabled).
But just to update. I deleted and reinstalled. Looks fine so far.
PetPet
Moderator
Moderator
Purify v1.1 released.
for those using Purify and facing problems with straits times or any website, drop an email to admin@purify-app.com
Edit : Oops sorry.
EldonChew
In review woh.
hellfire88
for purify users anyone knows what scripts and fonts are being blocked when you turn on?
still trying to figure out if i should keep scripts and fonts turned on. some websites seems to be broken when i turn them on.
