Google Nexus 7 2nd generation
swanpeach
selling nexus 7 2013 for cheap
selling my nexus 7 2013 for a low price, perfect condtions with box and all
message to 82906443,
16 gig wifi
hehuafa
Hopefully u have solve the problem, else u can just get into recovery, do a wipe and do a factory reset and restart.
To get into recovery, hold on to the power button untill the tablet goes OFF, after Tablet fully OFF mode. Hold on to power and volume down button.......after a while it should get into stock recovery mode.
It should be back to factory fresh start.
BUT first boot up after the factory reset m,ay take a while just be patient, everything should be OK after it start up completely.
Need help!!
After I charged my nexus 7, it's touchscreen become inactive, so I do a hard power down, and now it cannot boot.
Stuck at the Google word screen.
I tried to do a factory reset using method in xda, but still stuck at the same screen.
Anyone encounter same issues?
jchoong
I have installed this latest patch; I think it is for the stagefright fix plus other minor bug fixes.
Rickosw
what the price for this now?
feel like getting one and try
it is good but i wont recommend it when Nexus tablet 2015 is around the corner ... unless you die die one ... you can try HTC Nexus Table (but do go through the fourmn) - many horror stories ....
alternatively, wait till next week - 6 Oct, see what MSFT Surface Pro 4 has to offer ...
xmysticalzx
do you meant the nexus 8 which is rumoured to be out in late oct??
how good is it btw?? not sure if i should still get the google nexus gen 2 though.
