The Samsung Galaxy Note 5 Thread
jollyboi
Hi guys when I'm downloading apps on the playstore the download speed is extremely slow. This is not WiFi problem as other apps like YT and FB run fine? I already clear cache and data of playstore but still the same. Anyone have this issue and know how to fix it? Tks.
Sent from Nokia 3310 using GAGT
human_shieldz
Maybe cos ya downloading with Nokia 3310? :s22::s22::s13::s13:
Hmm not sure leh. Can you reboot your phone, close the Play store app and try again? Windows 101 :p
renfred89
turn off wifi and use 4g lor. if 4g works fine and wifi is not, then what do you think? :p
kEvinErd
I think it's the Google Playstore server side issue.. I've experienced this before when updating apps, not just in Note 5..but on my other devices.
firestingerx
Just in case anyone is facing the problem of the fast charger not fast-charging at random... Just replace the provided USB cable. At least that's how I solved it :)
keemmeng
Anyone successfully connected their note 5 to Mac to directly transfer files directly via USB? I tried using Android File Transfer but cannot detect note 5 at all
tkl23786
+1
Agreed.
Was using the provided USB cable.
Kept on having the Fast Charge not working all the time.
Have to plug in and plug out several times for the Fast Charge to work.
Changed the USB cable and now, Fast Charge works all the time.
Noticed the provided Samsung USB cable did not have a tight fit to the Note 5, compared to the non-Samsung USB cable I am using now which fit snuggly to Note 5.
No wonder the Fast Charge did not work all the time.
The connection was not as tight as it should be...
:s22::s22::s22::s22:
savage
My battery discharged by 30% overnight in idle mode while I'm sleeping. Not normal right? :(
Anyone else encounter this?
Sent from Sent from somewhere near Zoo using GAGT
I had something like that too. but it was because I had a bad signal to 4G at home. I switched to 3G and got full signal. After that, my battery dropped about 4-5% overnight with all the syncing and wifi on.
human_shieldz
+1
Agreed.
Hmm weird. Mine works perfectly. I cannot be that heng right.
benny888
Absolutely no problems on my iMac n with Android File Transfer. It could be poor cable connection
human_shieldz
Did Samsung exchange the cable for you?
What people find out if their phone isn't fast charging and yet don't wanna spend money buy another cable. Bring the adaptor and cable down then show them it's not fast charging and act blur. I haven't done it but i guess it will then convince them to replace it for you free. If they say wanna take your phone back 1 week :s13: to check then i got nothing to say
StanII
Anyone facing wifi issues on their set?
On 5ghz wifi, initially working, thereafter even though it shows connected, wifi can't be used.
