TsubasaX
Hi guys,
i recently bought ac87u updated to the latest firmware 9177.
i am on fibre 200mbps plan but on 2.4ghz i am getting max
50mbps but on 5ghz i am getting like 170mbps. is there any
setting i miss out in 2.4ghz ?
VANT
maybe You have interferences from other wifi in air ? Use inSSIDer and check this, change channel etc....
renfred89
Hi guys,
Maybe it's your wireless device that is slow lor..
kyo9012
Hi i need help. I use note 4 to connect 5ghz ssid but after few weeks, i unable to scan for 5ghz ssid and now i using 2.4ghz one.
thiamhui
Only Note 4 can scan 5Ghz or all devices? Are you able to scan 5GHz of neighbor? Usually the SSID will contain 5G behind.
If router is the problem, first reboot. Then try reset, then try update firmware. If all fail, RMA.
guards80
Firmware 9177
anyone have whatsapp call issue connect wifi on ac87u, call other side was on 4g network and i cannot hear other side speaking sound but other side can hear what i speak. but i try connect on both ac87u wifi on my home but its work both can hear the speaking sound. and i change router to 7009singtel set. no problem at all. either call other side on 4g network.
PiPiChew
Hi guys,
Generally speaking 2.4Ghz gives you range while 5Ghz gives you speed, at the expense of each other. So I would say is normal?
HyperBaka
getting a 1gbps plan and planning to get a better router too.
how much would this ac87u cost?
terencec
Dear all,
RT-AC87U_9.0.0.4_378_9110 - Unofficial Beta
Download: http://goo.gl/ud2RKQ
- Require factory reset after update.
Added
1. New wifi driver to improve wifi connection
2. Traffic Analyzer for monitoring your network traffic
3. Bandwidth Limiter in Adaptive QoS
4. USB to USB smart sync mode
5. A scheduler for Router Reboot
6. Can edit offline devices in client list
Update
1. Update OpenSSL to 1.0.2d
2. IPTV ISP profile setting of 'movistar' & ‘meo’
3. Adjust maximum number to 16 for Guest Network MAC filter
4. Web History/Traffic Analyzer can show device name.
5. Allow user paste password on login page
Fixed
1. Media server cannot scan files
2. Cannot complete QIS setting on IE11
3. Download speed is limited by Upload speed in Traditional QoS
4. Unexpected UI display issue
Best regard,
JK
Hi All,
Thought I saw there's a new feature - "scheduler for router reboot" on the earlier firmware 9110.
Think I might have missed it but I couldn't find this feature in both 9110 and the latest 9177 firmware.
Appreciate if someone could enlighten me on where I can locate this feature. Thanks.
ASUS@SG
Suspended
Hi All,
Dear terencec,
Scheduler for router reboot - Typo error
Best regard,
JK
ashtray05
Im seeing better stability on 5g with my iphone 6+ as well as better range.
I have channels set to auto and did a factory reset after fw update. Good job Asus.
terencec
Hi JK,
Thank you for the clarification. It is a shame to learn that it is merely a typo error as I thought it is a good feature to incorporate into this router. Any chance to have it included in next release?
pepeEL
Still problem with battery drain on ANDROID by 5GHz.
This is unacceptable in its class. I can not use it because the battery disappears in his eyes. When ASUS will solve this problem soon because I only heard soon
ASUS@SG
Suspended
Dear pepeEL,
We are waiting for the new driver to resolve the issue.
Best regard,
JK
Farish
ASUS@SG, any plans to release 9177 to Merlin so that he can incorporate it is his firmware? It has been awhile since he has released a new version thanks to ASUS moving to closed sourcecode etc. Pls be considerate to your customers who are still using ASUS hardware. Thanks.
Praxos
Best regard,
JK
JK
Had a question posed in another forum maybe something to consider for future firmware ? is this something easily achieved ?
@ Merlus writes...
["Can anyone tell me if I can use 30 minute increments for the time scheduling under parental controls?"]
["I want to disable my kid's internet access at 9:30 PM during the weekdays, but at the moment I can only set 9 or 10 PM."]
["Is it possible from command line or maybe the merlin firmware?"]
jovially
Thrust upgraded to 9177.
Notice an issues with guest wifi setting. It will affect my 2.4 and 5G wifi whenever I make changing to this guest setting.
Anyone have the same issues?
