so basically using HDMI cable also can been done right?
mib500 Master Member Joined Sep 16, 2010 Messages 3,309 Reaction score 9 Oct 5, 2015 #21 so basically using HDMI cable also can been done right?
monikernemo Supremacy Member Joined Oct 23, 2014 Messages 7,268 Reaction score 1 Oct 5, 2015 #22 mib500 said: so basically using HDMI cable also can been done right? Click to expand... Vga and dvi also can. But if got more bandwidth the range should be larger? Unless limited by panel? Sent from JARVIS using GAGT
S smackinghar5 Member Joined Aug 9, 2008 Messages 248 Reaction score 0 Oct 5, 2015 #23 Reppps said: 74Hz with my U2414H Click to expand... Do you mind share your settings ?
mib500 Master Member Joined Sep 16, 2010 Messages 3,309 Reaction score 9 Oct 5, 2015 #24 monikernemo said: Vga and dvi also can. But if got more bandwidth the range should be larger? Unless limited by panel? Sent from JARVIS using GAGT Click to expand... yeah... after google around HDMI should be fine but its limited.. most people test and can get around 76hz... interesting...
Reppps Senior Member Joined Oct 22, 2012 Messages 1,416 Reaction score 0 Oct 5, 2015 #25 smackinghar5 said: Do you mind share your settings ? Click to expand...
mib500 Master Member Joined Sep 16, 2010 Messages 3,309 Reaction score 9 Oct 5, 2015 #26 i successfully oveclock my monitor to 76hz.... thanks guys!!
