Xiaomi Mi 4i
mosmos
High Honorary Member
all of them have the remove account option? cos i have that option available for whatsapp account but none of the other account have that option.
yup latest miui
are you wanting to delete gmail app? may not be possible
you can try disable the gmail app in apps setting or clear cache or uninstall all updates that will clear all your email settings ~
kevin301
yup latest miui
Yup just checked Outlook and Yahoo. All have the 'remove account' option when I press 'more'
killerslayer92
i dont want to delete gmail app. i want to delete email account added to gmail app.
Closecl
does anyone know how much screen replacement at svc centre wld be? my screen has cracked even though i never dropped it and don't think this is covered under warranty. outside, the price i have been quoted is 150sgd and this is more than 50% the price of the handset itself =/
SpeedWeed
if covered under warranty.
quite possibly u can get it replaced free for the first time.
call them to ask
WhoDriveHonda
Hi does anybody have any problems with them "home button"? The bottom 3 touch pad thingy. Mine will siao siao one. Sometimes cannon press then something never press it will back for me or close the app all those
kevin301
I have the screen sometimes going 'crazy' when there is some moisture on it. So far always managed to get it working fine by wiping away any moisture with tissue paper, etc.
mosmos
yes, screen very sensitive~
mosmos
no such problems~
