In my opinion, filtered air comes from bottom will blow up the dust on the floor.
put upside down lor![]()
I've not left a review yet. Waiting for them to answer my question first. It's sealed luckily.that sounds horrible... and this is the "more expensive" listing that Goni have on the filter!
Btw, the pics in the review is urs? looks like the clear plastic is not sealed. You better seal it up with tape otherwise the AC filter can just throw away coz it's gonna be absorbing all the ambient stuff.
Or you can buy 4 pcs of xiaomi for under S$1k for 4 corner of your house.Still cheaper than the camfil(just guessing the camfil will be very expensive) and will filter the air even faster/better for sure.
And I thought GoniGlobal was ok because the purchase experience in Rakuten was good.
My Sharp A28 filter not replaced for 2years. placed foobot over top of vent: 196ug/m(3).
Anyone know where to buy A28 filter?
Dimensions is 280mm by 330mm by 23mm.
http://www.amazon.com/Fellowes-HF-2...&qid=1413201703&sr=8-5&keywords=fellowes+HEPA
Ok, Sharp A28 filter dimensions are 285mm x 310mm x 25mm. 1 inch thick filter
So the above Amazon H13 filter can fit. Slice up the 330mm to become 310mm (very easy coz the pleating is in the same direction) with a penknife. Scotch tape....the seal will be good.
285mm, need to use a strip of PU or LDPE foam and UHU glue to stick and cover the 5mm gap.
Or if you're not a handy person (like me, I can only destroy things), you can pay around ~$7/- extra to purchase the original filter for $44.94 (After GST) by going to:
438B Alexandra Road
#06-01/02 & #06-04 Alexandra Technopark
Singapore 119968 Tel: 6419 5222
I just received Qoo10 notification that my Sharp FU-A28 is OOS and the stock will arrived after 27 Oct. This is weird because their website indicate that they still have Qty: 42 left![]()
Just have to be mindful that the original Sharp replacement filter is H10, or 85% filtration efficiency @ 0.3 microns. (not PM2.5 which is 2.5 microns).
It doesn't matter a lot in real life, but i guess some people may want this for "piece of mind".
I found literature stating that Indonesian haze particle size distribution is 0.15 to 0.4 microns. Indonesian haze specifically.
Anyway, i have ordered a black one at $99 + 5 = $104.![]()
After Oct 27 is ok, today rained liao and i checked the cloud band is here . Confirm intermonsoon season. Jambi will follow v shortly within 1 week, Palembang after that. Wind dir would be very variable from now on.
Prepare for next year.
This is like a air purifier for purist but will need the gurus here to check its specs
https://www.youtube.com/watch?v=aMI-FoWvBAI&feature=youtu.be&t=101
Hopefully the prices are not like high end audiophile gear(e.g. >$20k).
Frankly I think Xiaomi or Samsung AX40 + Air-Conditioning should provide clean enough air for most of us.
the father steel say huan to fly her out of sinkapore to escape the haze. jin satki.![]()
Can call local agent on pricing i guess i was thinking abt how its air outlet being downward thrust might blow up dust....guess not
looks alot like xiaomi, but the app interface is so much better and a whopping 580m3/h CADR?:
