LG G4
falcom2002
can't decide to re-contract for a G4 or wait until Z5 release.. G4 $168 on Combo 3. Z5 maybe $298 or something.. sianz
A G4 is anytime having much more value than the Z5 in terms
of its usefulness...not to agree that it is best value for
the money now. You should grab it.
twlee88
yar, corner wearing out also. wanted to change back cover with wireless charging.
anyway, any good recommendation for wireless back cover and the qi charging station?
choetech fast charge is the best as of now?
Anything cheap and working?
Cnn0121
Thx bro.. Will try to see if this helps.. Cud u move files or download onto ur sd card when u say incompatible? Mine works well.. However, will try to remove it n see. Last resort is to go LG service. I can easily record an app coming active or photo album opening.. Tts how frequent it happens... Will update on what LG says on this...
Tried removing the sd card. No use. Same issue. Went to LG service center tis am. Either their mkt share is so low or quality is exceptionally good. I doubt its the latter after my experience... Nobody waiting to be served. Only one service guy sitting at the mobile repair counter. After he heard dual sim..almost immed say not sold in sgp, no hardware available n cant repair here. This will be the last LG set i will buy.. Period..
Oinkize
Bo pian.
Not sold in sg. What you expect them to help?
They might not have the parts to repair.
mungenx
anyone know where to get good clear, sturdy case for the leather back version? was looking at the Ringke Fusion series but not sure where to buy in SG. Thing is can order from qoo10 but not sure if it offers the variant which has no flash issue.
androidbot
First and foremost, my deepest condolences.. :o
I had a similar occurrence on my local set about 2 weeks back. This unearthly possession of the phone is rather a rare phenomenon. In my case, I had exerted more than the usual force on the screen while attempting to put it into the spigen slim armor case. I was so sure that my screen was a goner but by some divine intervention, after 5 minutes or so, it started operating normally. My G2 had a even more bizarre episode. That beast of a phone got possessed too and it did not end well for it. The screen just died after suffering for 3 days. Saving grace was that the warranty was on its last legs and LG replaced the mamaboard and screen for me after which, I sold it off. :o
Now, your only hope is contact the supplier whom you bought it from see if he can assist otherwise, bring it to a 3rd party handphone repair shop. There are many in Sim Lim and few at Bugis as well. Personally, I have ever patron the services of such a shop in Bugis for my Note 2 and the folks there were kind enough, to troubleshoot for me FOC. Price wise, they are about 200%-300% cheaper than the authorised service centre.
Anyway, I wish you well.
daniel_83
bought mine from singtel few weeks ago but price is chop carrot. Better buy from qoo10
Sent from LGE LG-H815 using GAGT
mungenx
the UAG case adds quite a bit of bulk too though right? Someone offered to sell me his UAG maverick for $20, not sure if should cop actually. I heard that the rubber sides also tend to come off easily after use? I'm more worried of the leather being scratched actually from taking off the case and all if its too snug also.
