Air conditioning - Any recommendations please??
ktyandkyc
may I kindly ask, after installing the aircons, how much electricity bill increase did u experience if u were to turn all 3 bedroom starmex (4 ticks) every night
kimsim
Suspended
Starmex current only 2 ticks.
1.92kw x 8hrs (7.68-9kw/h max.)
skai_11
may i know what is the difference between mxy-3a28va and mxy-4a28va?
i got a quote on mxy-3a28va, with 18k+18k+10k for a 4room new bto.
Any advice/comments?
toughnut
Hi experts,
Can advise me if this package worth it:
Mitsubishi electric system 2 9000btu +18000btu , condenser is 28000btu
Model: MXY-3A28VA / MSY- GE10VA
2 ticks $2750.00
standard material: Drainage pipe 16mm/ Insulation 1/2"
Wire - keystone
Copper pipe : hitachi 23 grade
18 month installation warranty
standard 5 year warranty by agent
Discount rate for maintainence and cleaning
2 trips installation
Can PM or share which vendor? Quoted $3k+ for same units. Thanks.
Boeing101
Intend to install 3 bed room and one living room.
Which is better:
1 set of MXY4A38VA.
OR
2 set of 3S27MKZ.
Its for my 4 room HDB.
Oh ya, GainCity tell me MXY4A38VA cannot pass through window of some HDB unit. True?
Boeing101
If i buy aircon, you think 2 tick better or 4 tick?
I know 4 tick save energy, but what is the disadvantage?
From my fringe experience, i will never buy more tick fridge anymore, the compartment not cold one. The ice i took out from more tick one melt much much faster than less tick one.
I think the tick is as bad idea as like our water saving device install at tap outlet. Its a piece of bad idea from someone on top.
kimsim
Suspended
So far 4ticks only, Daikin 20k btu sys 3, MHI sys 2 and LG artcool only.
But 5 ticks ME starmex coming soon..
For my experience, has more ticks meant can be reaching faster cooling capacity and cut-off during outdoor compressor time is a greater.
IF has more ticks but slower temperature pre-set are achieved in slower than 2 ticks, actually to be an equal also.
Usually more powerful needs draw more power input watts for shorten time than slower but use lesser input watts = energy saving.
At the end 4-5 ticks user still prefer to set few more stop lower temp. degree than 2 ticks energy saving model as well.
I previously did my aircon for 3.6k panasonic sys 4 (18k plus 3x9k). Got200 dollar ntuc vouchers also. From Aktiff engrg
I need air con for my mums flat again, anyone has any recommendations? If not ill probably go back to the same company. Looking for mitsu sys 4 inverter. Has to use good thicker pipes and excellent worksmanship. Saw creations on fb but they have atrocious reviews.
Thanks
smurf75
Hi , can anyone advise ?
Coming resale 5room flat 36years old, intend to install ME system4.
Will be partition out a room from living room so will be 4 bedrooms total.
MBR = 12k btu
3BR = 9K btu
Most likely will be on all the unit every night , will the MXY4A38 be enough or the new model MXY4G38 be better?
Thank in advance.
kimsim
Suspended
MBR = 12k btu
3BR = 9K btu
Thank in advance.
MXY4G38 all new design and outdoor slightly shorten, more easier to loading out from window.
smurf75
Thx for the advise , will the mxy4g38 limit to the 8.5A as HDB rule?
tlkchew
Hi Anyone can advice which Aircon is good for 5rm HDB.
I am changing out old aircon. 2x 9000 (Bd room) 1x 12000 (MBdroom) and 1x9000+1x12000 (living room) (fujitsu 5 in 1)
Thinking of 9000 BTU x 3 for room , what do your guys suggest for living room.? sshould i look for 2 x9000 or go with 1x18000
this is for standard HDB 5rm 110m2 in Sengkang.
thanks in adv
hOp3SoT
hey guys, can check wat is the issue if all 3 Mitsubishi units has continuous blink on the top light indicator after they were on for while and no air is blowing out? (after a power surge) thx!
kwaychapy
thinking of installing 1 x 18000 btu unit for living room.. nid another compressor + trunking etc.. any bros have had experience in adding on air con? i oredi have 3 units installed fornthe bedrooms..
