Air purifier?
kimsim
Suspended
This is original fr sharp or tb hepa? My a50's original has blue mesh. Im alway curious what that black spongy cube is for. Perhaps for the sensors?
Yap that is original hepa with white surface same as TB.
The cube spongy inside was the sensor.
Just empty dust cube spongy will do
Akai Ryu
Ahhh ok...without blue mesh might be good, easier to gauge hepa lifespan. the A50's sensor and perhaps previous models are behind the hepa with another one on top left near closure
kimsim
Suspended
Mind to sharp some pic?
Just in case the dust blockage on hepa, the sensor will be infective anymore
Akai Ryu
I do maintenance on a weekly basis but no blockage observed thus far. Look at the jap yt vid which i posted earlier to get an idea of how to do basic cleaning and where the sensors are for A50
Asakura
my advise for those who bought during the haze panic period and cant wait for delivery not to buy things from taobao during sale periods like 雙十一11.11 or 雙棍節 etc.. lol
Akai Ryu
My baomi is here! Trying it out now!
Similar blue mesh on A50 hepa
Akai Ryu
Compare to KC-A model, just remove sponge and wash on sponge will do.
The sponge thing is good for hair, fur etc coz allowance is too generous for dust coz still need sensor to be able to pick particulates for reading. Good to still vacc when u vacc the prefilter as microscopic dust may still be accumulate there although plasmacuster suppose to remove static charge.
Another area to look out for possible leakage and dust accumulatation is near the filter tank. Just use 3M filterete to cover those area if necessary.
Try to put ur ap further away fr wall for better efficiency
kimsim
Suspended
Thanks man.
derrickgoh
Wah either Philips damn popular or the re-stocking process CMI.
After so long finally see Philips purifier but only the 4012 and 4014. 4372 still no stock. :eek:
NWT1978
their brand of vaccuum cleaner good... Still using their Impact more than 10 years... Engine filter get at TB...cut to size lol =:p
derrickgoh
Me too but forgot which model. LOL. I went their online store also no stock for 4372 but anyway there no discount so forget it. Just hope Courts or BD stocks it soon.
xkirk
Testing out my newly arrived SamoAir counter and checking my AX40 efficiency. Thanks to all the bros here for dishing out recommendations. Room temp recorded is about 1-2 degree C higher than actual. I got a hot room, hotter than the outside cos it has 2 walls exposed to the sun during the day.
JoePilot
Naise!
Can calibrate with the 5 diff color levels of the ax40? I always wonder if the difference between green and blue is just eye candy
Sent from PAP Bedok HQ using GAGT
