Model number
Trans-Am
My parent has lost the receipt and everything which can help in finding the tv model number.
Is there anyway i can find the tv model number?
Ps i only know it is Philips smart tv.
mrsun18
I hope the tv is not lost as well?
Look behind the tv set. It may be difficult if it is wall mounted. You have to come up with a smart solution :)
Trans-Am
Mine is wall mounted, is there another solution?
jq75
Inside tv settings don't show product id? Otherwise slot HP behind and take pic or video?
sunsetbay
Moderator
Moderator
add your TV to into your wifi network and see what its shown on the ID~ :s22:
