Air purifier?
jimzephyr
Depends on your skill, you can open up the AX40 and stick a thick Blu-tack on the buzzer :s13: It's not complicated but you need to be comfortable tinkering with stuff.
Hi Chuanz,
Is the buzzer inside the shiny metal box or on the green pcb board with the LED lights?
I opened up but unsure.
The LED lights are also very bright and disturb sleep even though I tape the outside indicator area and cover it.
Thanks. :)
chuanz
Hi Chuanz,
Thanks. :)
On the board IIRC. Should see something like this.
Disclaimer: it's been a while since I opened my AX40 up, can't remember exactly liao.
meesoto
TB seller misplaced my order and has re-sent a replacement. Problem is, I can't see it anywhere in "我的淘宝" > "已买到的宝贝". He then gave me a Order No. Can anyone tell me where to go to look up this number?
Thanks.
sehsuan
just placed order for 2x refurbished xiaomi AP's for about 165 SGD each last night... can save extra money for "warranty" that doesn't exist in SG 😁
kimsim
Suspended
Huh but the jet plane sound do u don't mind?
Please share the link, I need too :D
Akai Ryu
Looks good... which version to hoot? The wifi one is to connect to handphone apps?
Based on my limited chinese vocab, yes. Looking at the co2 and pm2.5 plus wifi combo...believe can read ur home air quality if unit link to wifi at home.
sehsuan
u gonna mod the plug to local 3 pin ?
shouldn't be hard. most power would be 2 or 3 pin IEC style.. if it's some obscure cable, just cut cut... and replace with a locally usable plug. settled 😊
main thing is 220V...that's more crucial.
mindgamey
It comes with a detachable IEC cable.
Can just go buy a UK 3 Pin to replace.
Akai Ryu
Key features include: dual-tied fan, CADR values up to 750m³ / h or more, is LIFAair CADR full range of products in the highest value of a deal for more than 80 flat decontamination area requires only 18 minutes. Kill bacteria, using powerful filtering technology 3G, for PM2.5 primary filtration efficiency up to 99.97%, to capture fine particle size 0.001um (1nm) particles. Periodically automatically open ultraviolet light disinfection, to kill the bacteria captured by the filter, to prevent secondary pollution.
Get rid of smoke, in addition to charcoal smoke completely follows the net filter LIFAair of 3G technology to completely remove the smoke. "Anti-acid" type in addition to formaldehyde activated carbon filter, which can accommodate 4 kg of activated carbon, formaldehyde absorption capacity fully guaranteed. • After LIFAair unique technology process activated carbon, activated carbon does not produce other purifiers prevalence of "sour" taste, so as to prevent secondary pollution.
主要特点包括: 双并列风机,CADR值高达750m³/h以上,是LIFAair全系列产品中CADR值最高的一款,应对80平以上净化面积仅需要18分钟。 杀灭细菌,运用强大的3G过滤技术,对PM2.5的一次过滤效率可高达99.97%,可以捕捉细至粒径0.001um(1nm)的颗粒。 可定期自动开启的紫外线消毒灯,杀灭被滤网捕捉到的病菌,杜绝二次污染。
祛除烟味,除烟味活性炭网完全沿用了LIFAair的3G过滤器技术,能彻底去除烟味。“防酸”型除甲醛活性炭滤网,可容纳4公斤活性炭,充分保证甲醛的吸收容量。• 经过LIFAair独有技术处理的活性炭,不会产生其他净化器活性炭普遍出现的“酸”味,从而杜绝二次污染
Maybe this is why some are complaining of weird smell coming out of their AP
sehsuan
WussRedXLi
Thanks.
Buy another item from seller, 2rmb...(chg price). Input ttacking no.
If not, u cant consolidate.
Alww 4px cso can...but will be single item pump out of SZ
simplesweet
Hi, just got the Honeywell True Hepa allergen HPA300 3 weeks ago. Open and check the filter, the pre-filter was so dusty!! Was amazed! Anyone here DIY Honeywell HEPA filter from Toabao as well?
autumni76
May I know if anyone purchased any of the following air purifiers and what is your feedback.
-Lotte
-Whirlpool
-Delonghi
-Winix
-LG
-TCL
Thanks in advance..
