Xiaomi Mi Note
anirudhks
thanks all looks like better to stay with the note .. :) loving the china dev rom . very good battery life i am bit of a light user i get almost 2 hours of screen time with 70% left at the end of the day .. just super!
KeYoKe
dont even know how to download chinese dev rom. super slow download speed and download disconnected halfway
arcaninx
This model is not.compatibe with a number of apps like bloomberg and mytransport@sg
Anyone else facing this issue?
sevensomerset
is it possible to flash mi note to vanila android rom?
currently using nexus5, on marshmallow
like to, so far
just the nexus5 batt sux, need dual sim slot
oneplus 2 seems nice, but mi note spec nicer, especially the hi-fi DAC chip
anirudhks
like to, so far
stock android on mi note will be very slow updates , as far as i know only asop exists , there wont be a cm12.1 or 13 , if you prefer that type of roms and features oneplu2 is the better option
SpinTop
Cannot connect to Singtel Wifi at all at the shopping mall.
anyone having same issue connecting using Mi Note, on Combo plan?
anyone got the solution, appreciate it
thanks
mehmeh91
thanks
i have the same problem with my redmi note 2 too, cant connect to singtel wifi at mrt station etc :s22:
SpinTop
Issue resolved, solution is very simple.
someone in Mi forum found the solution. thanks to that person.
switch sim card to slot 1, fix the problem
i got a sim adapter
enjoy the wifi speed while its still free.
