Air purifier?
gravavva
Based on the specs 5W on high :eek: Super low power consumption. Suitable for a small bedroom maybe? Not sure about the CADR... figures look weird to me.
I personally find it hard to believe. I pointed the B4 intake towards the output of this thing and didn't get very significant results. Like 20?µg/m³ lower than the surrounding area.
Maybe it works but it is not strong enough to clean a room that quickly at least.
Akai Ryu
Filter exactly the same as that habanero at qoo10...reported to be crap by a user here iirc
Astro
In transit INCHEON-SI JUNG-GU KR
Goni finally sending AX40 since 2oct
Akai Ryu
How come charcoal you need change?
Can put on outdoor direct sun for few hours should be ok already.
The pores of the charcoal will chock up eventually and let particles through. Think sponge. But unlike sponge, the molecular particles does not evaporate under uv or heat. What sunning does is just release some moisture absorbed and allow some chemical reaction to occur for voc to dissipate. Activated carbon will not last as long as hepa therefore i favour those seperate type which allows me to continue and use the hepa
Akai Ryu
Try microwave any used activated charcoal if u got chance and u will noticed all the mositure being release.
kandinsky
Hmm seriously :(
Like that really have to spend more in future
Maybe depending on the design of the AC layer, wonder if it's possible to DIY and reuse it. E.g., Slice open the top and reseal after replacing the spent AC with new AC? *Shrug*. Can get AC from aquariums.
dqwong
2 weeks after using Xiaomi, the Xiaomi app shows 7-9 instead of the usually 3-9 for air quality. Took out the hepa filter and vacuumed it. Now back to 2-4
Asakura
well said.
i bought few sets from them way before October. all delivered without issues. those families using happily before people started panic buying
The only people that don't want others to buy from Goni is because they panic buy because of the haze during the holiday season in South Korea...By the way what is the colour of your air cube? Mine is Gold...
sehsuan
i hope you don't mind me mentioning the obvious... ensure your vacuum cleaner's on HEPA too, if not it'd have a field day spreading out some level of trapped PM10 back round the home :D
autumni76
Dunno... i bought the airvax a few years ago. Seems ok. Air better, but as time goes by, i think filter dirty so i changed the filter.
Also bought a habanero.
but strangely, airvax said their filter life span is 3 years.
habanero said their filter life span is 1 year.
And I compared both.. seems similar to me.
if must keep changing filter damn sianzzz..
anyway, still hunting for good true hepa filter air purifiers that will not have any outgassing issues and can truly clean the air.
dqwong
I use a portable car vacuum to vacuum the hepa outside my house, vacuum exhaust pointed away from my house(don't tell my Neighbour)
dqwong
My Samsung fridge manual instructs to soak the active carbon for 15mins and dry in the sun.
Pandaeyed
Thanks Goni for finally solving my problem. To be fair they took 3 working days to reply to my video.
Samsung Singapore (Commonwealth branch) checked my purifier, then they t old me my motherboard is spoilt (just because they want to earn my money $200 to change motherboard SG! ) its either they are very clueless or dishonest and greedy
Samsung Korea and Goni global told me the reason why lights are blinking and not functioning.
Here is the solution
The reason all the lights are just blinking is because the options is unset.
This problem can be solved by
1) Unplug the purifier,
2) Connect the plug,
3) press Menu button + Lock looking button for 3 seconds (it will make a "ting" sound),
4) Press menu button + power button for 3 seconds (it will make a "ting" sound),
Thats your option set.
5) Unplug your purifier and connect, it will work normally.
Hope it helps everyone
gravavva
Starting to get sick of those who recommend products even though they don't have a particle counter to justify them. For anyone interested in buying any APs, please read the recommendations from WRX to be safest.
P.S. Semi tested Airvax and Go-Clair, against B4 (laser particle counter) and I do not recommend them.
Asakura
airvax not using hepa filter
go clair using their own technology. e2F filters
makav31i
You all think vacuum cleaner with water filtration vs those with bags or those hepa would be better to clean air purifier filter?
