LG Roboking
IceLatte
To switch the language of your RK, (6370/6470 onward), press and hold the most right button on your roboking. Then it will announce the current language. Repeat to switch between the languages provided. I think 6340/62xx might not have english.
I have also found a link that can be saved as html to use.
LG Map BBL
Basically if you know how (for those who has applied soft patch etc), the flashdrive that you used will retrieve the mappings of the past cleaning duties, (scheduled or manual) then it will display the whereabouts and trail of your roboking.
Anyway, previously I thought my sensors could be malfunctioning but Roboking Diagnosis always report with no defects found.
Apparently flashing the software makes it ok again, but after a few weeks, it will happen again. So no harm trying to reflash it as and when.
As mentioned by one of the bro here, you probably could bring your Korean export sets to LG SG directly for repairs at a cost of labour and parts.
LG Roboking seems to be quite outstanding, at least for my expectation of being a clean freak guy. Helps a lot when i leave my place over weekends, comes home to a clean floor, except for the few hiccups of not returning to base randomly. :s13:
Hope it helps.
mooscenic
interested to get 1 as well.. but like no takers for it - to know how to switch to eng.
Hi all, I just bought the LG VR6340LV from Qoo10 for $424 ($389 + $35 for delivery) in case anyone is looking to buy one now.
On Carousell, someone can change the language from Korean to English for $10. He listed the model as 6270 so not sure can it be done for my model or others though
invisible.hippo
for those using 6470, did you guys charge before using? is there requirement to charge 8hrs before using?
CyberTron
Does anyone knows if all models of roboking shares the same battery?
I went to autovacstore website, they seems to list the battery is suitable for 6[1-4]xx models.
I'm trying to get a replacement battery for my 6370, which seems to be dying.
Does anyone know if there are any firmware update for this model?
thewiseone
Its the same battery. Go down to LG Singapore and get it. $60 / $65 if i recalled correctly.
CyberTron
Thanks. Got it from LG service center today. For those interested, it is $65 + gst. Also got the front corner brushes, is $8 each, so total $16 a pair + gst.
For the battery, I noticed it is a bit different in shape than my original one, and it seems to have a higher rating. The original is 1.9mA while the new one is 2.1 or 2.2mA.
furyoo
Hi all. Want to check with you guys on something. Do any of you have plush carpets? Will the brushes get stuck on them?
I ask because my current dumb robot always mounts the carpet and gets its brushes stuck on the carpet hair.
thewiseone
Any latest good bots recommended to get ?
