LG Roboking
DigDub
this one like very tall to get under cupboards and sofa.
my colleague bought a Monueal brand one, can vacuum and wet mop. seems like not bad.
invisible.hippo
anyone know who come during night(5pm), the robot will keep on going on vacuum till battery run out? It does not happen during day time(10am).
How to prevent it from mounting the fan base and keep getting stuck.
derrickgoh
Lol. Your bot is possessed. Attach mop plate to it
thewiseone
There arent many reviews for this model and not all reviews are negative.
IMO, Samsung has never produced a decent robotic vacuum cleaner UNTIL this model. So, whats so great about it?
1. Very strong suction. If u disassemble the entire filter assembly, u will see that the vacuum path has to go through a very thick foam padding before the filter. Yet, despite of the thick obstruction, the exhaust flow is still very strong (easily rivaling the Neato).
2. A large bin with a unique design and cyclonic flow means u dont have to empty the bin so often. Used on a daily basis, u dont even have to empty the bin for 7 days or more since the filter isnt clogged with debris like most other robotic vacuum cleaners.
3. Adaptive learning capability. First couple of days, u may notice that the bot can get caught up in some areas and it will stop. Simply start it again to continue (and keep doing so if it gets stuck again). After a few more runs, it wont make the same mistake anymore. In addition, it always managed to navigate its way back to its dock every time. Some reviewers may not have used this bot long enough to experience its true capability IMO. :s8:
4. More gentle on obstacles with less blind spots as compared to the LG Roboking.
Iirc, the reviews for this is not fantastic
Gribber
You are making me confuse now :o
which to buy... argh
thewiseone
Simple.. the Samsung is quite a fair bit more expensive than the LG Roboking. If u are prepared to spend this much, go for the Samsung. If not, the LG Roboking is a decent bot for the $$$, especially if u purchase one from Qoo10.sg.
Gribber
ok, i will go compare them in detail again before commiting to either. I like the fact that even if we purchase from Qoo10 - LG can still fix it / get replacement at minimum cost. No idea if its the same for Samsung.
thewiseone
With the unit turned on, press and hold the 1st and 3rd button (top row) if i recall correctly. Believe it was mentioned b4 somewhere in this thread?
How to "reset" the roboking to make it relearn from scratch like a factory reset?
punkster
my roboking 6270 is not working too good after the latest firmware update, anyone know where i can download an old version of 9785 firmware?
snowicy88
Hmmm, thanks man. was thinking of getting the samsung one
thewiseone
They have a lower end 2015 model for this series.
Largely similar to the white model except for:
1) No laser pointer to direct the bot
2) No scheduling
3) Smaller display screen on the bot
Comes in 2 colours, yellow or red. Unfortunately, this lower end model is only available in Korea. If u happens to make a trip to Seoul, u can get it from Lotte Duty Free. Price is approx SGD840 after conversion. Alternatively, u can check to see if its available on Ebay. ;)
Samsung crosses 1k for that model :(
DigDub
how was the review on this so far?
didn't check with my colleague.
anyway, saw another brand at jems isetan, can vacuum and got a small water tank attachment at the back for wet mopping also. can't remember the brand and model now, but its a sg company.
kaydee
Dear all roboking owners.
Been using roboking for a few months and I have this problem.
It sometimes left tyre marks whenever it turns/change directions.
Any ways to solve this?
Lost_Found
izzit innobot?
Lost_Found
Can't seems to find any review on this brand. Anyone currently using can comment?
Sent from Asus NEXUS 7 using GAGT
Rivers
Does anyone have the issue with Robo king just working for a few minutes and then stopping saying that cleaning has been completed? Never had such an issue before.
Any fixes for this? Thanks.
