Let's DELL
micheloving
paiseh confused by the different pattern mode of Dell inspiron 24 7000
here is the correct one
http://www.dell.com/sg/p/inspiron-24-7459-aio/pd?oc=w210705sgw10
SG: $2,049.00
http://www.dell.com/my/p/inspiron-24-7459-aio/pd?oc=w210811myw10&model_id=inspiron-24-7459-aio
MY: 5,999.00
This is the correct price~ quite close in term of price but malaysia got cheaper version de this two pricing is i7
Dell warranty can mix spore and malaysia one meh? Go malaysia buy still got warranty in spore?
Gribber
No need la what are the chance.. For it to break
Then again, my notebook bought in malaysia can be serviced in SG. Their onsite come Somemore
xiaowhois
got ppl stay in jb but work in sg mah :)
buy from Dell Singapore if you stay in singapore
buy from Dell Malaysia if you stay in malaysia haha
koreanlover
SG: $2,049.00
MY: 5,999.00
Get in Singapore better? Unless you can claim warranty for the Malaysia Dell Inspirion 24 7000 in Singapore too.
koreanlover
must see what you wanna use the intel realsense camera for lo~ if for video conferencing ofcause can on Inspiron 24 7000
like play racing car game also prefer got the steering wheel than got the feel mah u hold air when using intel realsense where got the feel haha
Playing the flight simulator using Intel RealSense without the joystick looks weird.
koreanlover
No, it seems like it must require a 3d camera that can detect depth like the Intel RealSense Camera 3d sensors technology or Microsoft Kinect.
The Intel RealSense 3D camera only does facial recognition right? No iris scanner and fingerprint scanner for Windows Hello login?
evilster
ya, flight simulator need the freaking vibration to feel the ground and everything mah. if u fly with the intel Realsense is so weird... Maciam doing bomoh ahah
koreanlover
seems like Malaysia starting price of Dell Inspiron 24 7000 with Intel i5 cpu, Intel realsense camera and Window Hello , from Rm4999 (SGD1500) for lowest specs, not cheap either~ :s22:
Wow looks stylish and ultra thin but expensive.
what88
thanks admin
sadly I guess wrong.. thought is doing 3d modelling from the gestures but is playing space astro blaster :s22:
so only Dell Inspiron 24 7000 AIO has the Intel RealSense 3D camera?
Dell also has Inspiron 23 7000 AIO but seems like no RealSense..
Thought both should have as the different between these two models is their screen size.
koreanlover
The revolutionary Intel® RealSense™ Camera uses depth-sensing technology so your PC sees more like you do. Use the added dimension to scan 3D objects, control your PC with gestures, or create a more lifelike video chat environment. Reinvented video chat lets you customize your background, and share content with friends as if you're in the same room together.
Seems like Intel RealSense is good for gaming from short distance from the monitor.
