To chamkw2002,
They need to vacuum the pipes first before releasing the gas into the pipes and test run the system.
What temp do you set for your master room?
They can check by the gas level or fancoil coil coldness.
Terumo,
My MB is 13000 BTU, i set temp at 25 with fan 3, feel cooling but not those type of coldness. i'd try to set it to 23 Deg and its cold.
From what i saw, he just connected all the pipes to the condenser and immediately he turn on all the gas valve. So if they dont pump down the line, will it cause anything? compressor lifespan shorten? Noisy?
Hi I'm planning to install aircon for my house. This is my first time purchasing aircon. Wanna ask usually where do ur buy aircon? Courts, best, gain city or any other reputable dealer?
Thank you KimSim for your reply,
so what should be the the correct pressure for MXY-4A28VA compressor?
Coolserve spec for this compressor is 30366 BTU. Why they told me is only 28000 BTU ?
any1 can help? Planning to buy daikin brand. Went to courts but they never sell daikin brand
KimSim, do you know how to adjust to 11A input current or there's a procedure to do it?
Corrected pressure should be around 150+/- for inverter model. Need to check with experience Aircon man as well.
4A28 the actual BTU Max was 30k, but after factory setting to current limitation lock at 8.5A, left 7.2kw X 3412 = 24.56k BTU only, unless you do the same like me go to adjusted the current input for 11A to be maximum the input watt as well.
Faster cooling and higher BTU but pay slighly higher a bit.
Otherwise go with 4G28 will do
Is toshiba good? 3999 for sys 4.
Compressor 34k
Hall 24k
Room 9k x 2
Masterbedroom 12k
Made in Japan.
Speed was so strong as well compared to starmex
How to adjust the current input? Using the 3A28VA. Running 1 each of GE10, 13 and 18
To Neverland99,
There are referring to the same 5 ticks model, MSYFJ10 & MSXY-FJ.
Different companies might have different way of stating the model.
