The Samsung Galaxy Note 5 Thread
StanII
anyone facing issue where your note 5 is not going into deep sleep?
always staying at 400Mhz standby even when screen is off?
renfred89
I'm using an app called cpu spy reloaded. Can see the various speeds the phone is running at and the duration.
i see... well, indeed 400 is a bit high..
perhaps u have something running in the background?
renfred89
Hmm 400mhz is the lowest, do you clear your recent apps? Read that clearing isn't good.
misconception again.. if clearing is no good, it won't be there in the first place..
lets not dwell into the code and explain why its no good or why its good..
but in layman terms, the cache and apps will usually be managed by the system itself. clearing the caches and closing the apps from multitasking menu will only kill certain applications which usually hog the ram..
greddy88
Does anyone notice there is this app optimizing happening frequently?
Any issue to leave it be or better to turn it off?
banana10
Anyone having issues while listening to Spotify?
so usually when listening music, we let the app run in background right?
ok, so in the middle of listening.. sometimes the Spotify app closes by itself (not has stopped working/error). It's like when we clear the RAM while listening to music, the app is gone right?
same thing like that.
Anyone having this issue?
Is it the Note5 too aggresive closing apps, or is it Spotify's app that is the problem?
renfred89
I have this issue too. Confirm is spotify's app issue. I have the exact same app version on another note 5 not running OJD, it has no problem.
The point here is that, the developer needs to provide an update in order to suit the OJD version more appropriately...
skipper
Yup having the same issue despite having taken out from optimisation.
Sent from Samsung SM-N920I using GAGT
