Xiaomi Mi 4i
killerslayer92
mosmos
High Honorary Member
lots of talk. no numbers
not sure if its miui7 cos 6 i also experience dropped signal
then again it could be location bcos the signal always drop around that area
I have 2 mi4i, one with miui 6 other with miui 7, signal strength same, while start up any app or camera app, miui 6 was noticeable faster.
miui 7 set runs hotter at the back near to camera lens while miui 6 was cool.
miui 7 display seems brighter and whiter colour display, previous miui 6 set to 25%, miui 7 need set to 18%
battery wise, did not notice any diff~
WhiteAnt
anyone knows what are the mi4i whatsapp notification led colors?
because i set as cyan but no such color when got incoming message :(
WhiteAnt
i use white no problem
ok then i try white
then how come when this is when phone is resting, the whatsapp msg sometimes will pop up the screen and sometimes won't? i already set the setting as always pop up :s22:
mosmos
ok then i try white
maybe is grp msg? chk your personal msg and grp msg settings
WhiteAnt
i put white as personal msg and purple for grp.
only purple light seems to work.
white color light i haven't seen yet :s22:
finally got white color light for individual whatsapp notifications :o
somehow, the notifications are not v reliable imo... smetimes got light sometimes no light. or issit only me :s22:
Janet90
Any advice on this ?
Im thinking of getting of either getting this locally from mi sg or redmi note 2 prime from xiaomi tmall .... anyone used both of this ? Can provide me with that own exp ?
Only looking at the 32gb versions ..
TIA :)
RaptureM3
not sure about redmi note 2 prime but the mi4i quite laggy, from my personal usage experience. maybe you can try at mi store sg first
caterham7
TIA :)
If you are looking at xiaomi tmall, can also consider mi4c
sadboy
Anyone front camera issue fix after many firmware update?
I got this device on 1st release date. The front camera is like a lot noise and cant be used.
After now miui7 the front camera still same issue.
Wonder if this is hardware issue rather then software/firmware.
havcove
just gotten a xiaomi4 as a spare phone, anyone can recommend a physical shop to buy covers or cases for it? the free case that came with it seems useless.. even though it is a spare phone, would also like to take care of it.
thank you in advance.
mosmos
since it's a spare phone and free case, you should not in a hurry to get a case~
just get from qoo10 or lazada, quite cheap there~
havcove
thank you, it a spare phone, but i be using it whenever i go overseas and it does cost $ so still wanna get a hard case cover, :)
killerslayer92
does anyone see ram usage increase? last time i usually get 500mb free. now is 300mb
if clear all apps last time 1gb free. now 700mb free
