Let's DELL
jtec14
I think should be Dell XPS series le since it is consider as last week of the contest.. Dell Alienware Alpha like nothing much to discuss...;)
Oh yah, top prize have yet make it debut, look like high chance you are right for next week video teaser.
wadsad
Since windows 8 and above, we are able to use touchscreen to navigate in the OS. Using touchscreen would be more accurate and faster in navigating around the software
So Dell Inspiron 7000 series able to utilised the full function of Windows 8, while Alienware still a step behind, though for gamers, the laptop was not always for games, there can be used for productivity software, designing software, etc
yup. touch screen is definitely a must have.
mosmos
High Honorary Member
Msi is called gaming dock but based on the date released, i would say Alienware is the first one to release their Graphics Amplifier.
not exactly a silly invention for a laptop, the Alienware Graphics Amplifier provide an ultimate gaming experience where you can use your laptop like a desktop as you can connect the monitor, keyboard as well as mouse to the Graphics Amplifer.
it gives you the power of a desktop graphics card and pushes up the frame rates to higher levels. it is also future proof as you can just change the graphics card to newer and more powerful one rather than buying a new laptop.
:s22: What happen if in future new Dell Alienware laptop decided to have a new connector to the new Graphics Amplifier?
eventhough can upgrade GPU but means the old Alienware Graphics Amplifier system going to collect dust if the old Alienware laptop spoilt?
We have seen Apple removing older connectors in their laptops, not sure Dell will follow suit.
mosmos
apparently you can do RAID setup on Alienware systems :s22:
http://www.dell.com/support/article/us/en/19/SLN116365/en
Are we able to RAID using one HDD and one SSD in Dell Alienware R3 Laptops since there was an extra SATA slot?
Will there be any effect on the battery life if we using RAID in Alienware laptops?
A picture of the exposed 4 m2 expansion bays, the easily accessible back panel where you upgrade the ram and 2.5" harddisk. You can safely do without voiding the warranty. Alienware 17 can be self diy to be as powerful storage as desktop PC
will the Dell Warranty be void if we DIY changed the ram and HDD?
jtec14
looks cool but not very partical unless you wanted to sit down on the chair and play on the table, the glowing lights are distracting to eyes too~ :s22:
I still prefer a laptop like Dell Alienware 17 R3 or Dell inspiron 17 7000, sometimes tired can just unplug from the mains and put the laptop on bed or sofa to continue my gaming or net surfing~
I also find it distracting. Old man here, I can't even stand working in a dim environment with my old trusty PC, a normal intel i3... :p
wadsad
none. wont void one.
jtec14
So this week video teaser is Dell XPS, family of this campaign 1st prize XPS 13.
From google, wiki, XPS stands for Xtreme Performance System and the name emerged as far back as 1993 and it was for desktop and tower only till now for laptops.
Surprised that it is considered as another powerpacked range of PCs/laptops along side with alienware. Look like Dimension range are more for the mid to low market?
Some history, just realised Dell did not come up with Alienware, they actually bought over the company in 2006 and it took over Dell XPS line in gaming desktops later on while XPS are scaled down to laptops only.
jtec14
I believe they do.
Alienware 15 has 2 m2 slots
Alienware 17 has whopping 4 m2 slots!
Wow serious? Really a performance packed range of laptops, no wonder the premium pricings. While it is considered overkill for my own usage, I always have misgivings that it is not really worth that price but I have to say that these few days, after reading from all the sharing here, I realised that alienware is really priced for its solid components.
wadsad
not likely they will do this bah.
Ohayo!
I dun tink 4k uhd is necessary for laptops due to screen sizes, max 18" for alienware range? Really can't see the differences bah. For touchscreen, I also have the opinion that while it is good to have, I still prefer keyboard and mouse for action packed games, hands can rest easily on table also. Imagine hands raising and pointing at the screens for a prolonged gaming sessions. Tiring man.
And I thought Dell Inspiron 24 7000 is an AIO, not laptop? :p
All these are good to have but not required. Should make it an option for all users.
dell alienware got touch screen + 4k UHD what.
Previous Alienware 17 R2 laptop offer touch screen but their Alienware 17 R3 dont offer it. I guess people might actually buy the predecessor if they really want to utilize the touchscreen features.
Both of these will certainly affect the long battery life but it certainly can enhance the gaming experience of gamers.
I think most people think that gamers only play fps or those point and shoot games but if you check on steam, there a tons of indie games which people buy and can take advantage of touch features. These indie games dont take up much graphic performance power so then again they may not be suited for the gamers which Alienware is targeting.
mosmos
I like to see Alienware do a take on slim gaming laptop at 15.6". They are gaining popularity and the other brands have this line of laptops, but the limiting factor of the small casing limits heat dissipation and causes throttling, those with slim laptops have GPU/CPU running 80-90 degrees.
I believe the problem can be solved with more investment in this category. It can be a rebirth of liquid cooling in a laptop because of higher efficiency of water, smaller heatsinks are used.
Dell already have the XPS15 and Precision 15 5000 of slim powerful workstation class, a tweak here and there with cooling and a slightly thicker bottom can work.
The specs of such a laptop should be gaming grade , so a quad core i5 6300HQ configured down to 35W, 2x8GB of DDR4 ram as it is more efficient than DDR3 and GTX 970M, 256-1000GB of m2 SSD, and must include the graphics amplifier connector.
Other than leaking into your bag wet, Liquid cooling system may cause the overall size and weight of laptop to increase, making the portable gaming system more unattractive
Dell Alienware should design something lighter, sleek and stylish like the mac book or Dell Inspiron 24 7000 or Dell Inspiron 17 7000.
Since Apple can squeeze in a powerful system into ultra portable, Dell Alienware should have the same expertise too.
Ohayo!
Hopefully there will be adapters to enable backward compatibility for such gamers then.
But since the Alienware Graphics Amplifier FAQ states that they will support future graphic cards released, I suppose it wont be much of an issue since gamers can easily install the newest graphic cards which can provide even greater power and performance than the current ones already in the market.
So i doubt that they will change the connector since the Alienware Graphics Amplifier can be used with the latest graphic cards.
what88
Did you go to check if Dell XPS come with Intel Realsense and Windows 10 Hello? =:p
what88
Didn't know Dell Alienware 17 R3 did not come with 4K UHD touchscreen.. :s22:
May be serious gamers dun have extra hand to use the touchscreen..
mosmos
i would prefer Alienware to come out with a laptop with very good cooling system becos the heat generated from the graphics card as well as processor would be alot. long term use would degrade the lifespan of the laptop. also if they can reduce the weight would be even better.
For Alienware 17 R3 laptop or Dell Inspiron 17 7000 laptop, other than liquid cooling or fans cooling, they can consider cooling gel in the laptop~
Gamers would benefits from noiseless portable system.
xiaowhois
That's why i say... boo to the use of proprietary! But i think we got someone in thread here who bought the Dell Alienware 17 R3 so not that hard bah... Anyway, imagine if macbook pro or desktop can use... :love:
How many SLI combos... :love:
definitely you dont expect apple products use it unless apple ownself introduce their own version of Alienware Graphics Amplifier. you like it or not company will use proprietary connector. Company will like to have something over their rival in this case Dell for Alienware Graphics Amplifier while MSI got theirs too
mosmos
Just enable Turbo Boost (if it has not already been enabled by default) in the BIOS would probably be the safest. It will run when you set your PC power options to "High Performance". I wouldn't recommend newbies who don't have any knowledge and experience to use Intel XTU to overclock their hardware in the Alienware laptop.
Intel XTU is quite complicated and has a lot of options and may confuse newbies. Better to stick to the overclocking tools which many manufacturer provides like those 1-click tool. Can gain a bit of extra performance also good.
Turbo Boost as in Alienware laptop or Dell inspiron 17 7000 ? Or only in DIY cpu system?
xiaowhois
I do agreed on this. Better cooling system definitely will help in laptop performance but at the same time this will increase the weight/size. It is a not a easy task for the manufactures to overcome it. This is the reason why Dell came out this Alienware Graphics Amplifier for serious gamers where it will help to reduce some stress of the Alienware stock GPU.
Maybe you can just buy a notebook cooler bring it out if you know u will use the Dell Alienware laptop intensively or use it at home when gaming
xiaowhois
mosmos
Having 2 M.2 slots is already very well sufficient for everyone. I feel that they could have further optimise the internal layout better to pack slightly bigger battery to improve the meagre battery life or for heatsink to cool system better on the 2 x M.2 worth of space as it seemed more like a slab of wasted space there. Who seriously will uses that many M.2 SSDs there?
Can we removed the HDD and replaced with SSD connected to M.2 slots for Dell Alienware 17 R2?
I have a SSD and it runs much hotter than my laptop HDD, I wonder why with no moving parts, SSD should be running much cooler.
I hope Dell Inspiron 17 7000 should also include some empty slots for us to upgrade.
