thefernwehronin
- Sep 28, 2015
Bring it back ! lets go retro!
Cheers,
tfr
i miss 8250 as well
Now then it starts to make Android phones. Maybe just nice market change again Windows Phone becomes popular...
Nokia will kick itself again. There is a Android phone fatigue with the market flooded with cheap Chinese phones. Even Xiaomi and Lenovo are starting to struggle to sell more phones.
bro do you think that Samsung will be affected. To be honest i think their phones are not bad but just that is a little pricey. what do you think?
Cheers,
tfr![]()
I am considering buying an export set Nokia 105 to use as a work phone with prepaid SIM, just to receive SMS, and maybe as alarm clock. $28, no warranty, still considering, haha
will not work in singapore after april 2017.![]()
sorry, can you elaborate more? I don't understand
2g will be shutdown from april 2017.
but you can continue to use it if you can get signal from indonesia or malaysia.
which means it is better that I can a phone with at least 3G?
yes, it is...
but beware of credit leak...so make sure data is turned off at operator end if you dont use data.
Which other low cost Nokia 3G phone you would recommend? I only need to use it to receive SMS.
check this:
http://www.gsmarena.com/results.php3?sMakers=1&s3Gs=UMTS900&sOSes=1
if you are willing to spend more than $28, you can consider the NS phone 207/208 that happens to be in discussion in this nokia subgroup.
i'm trying to get a 6700 slide because i prefer a more metallic look and support for mini sim.
