luggages on TRA trains
Kc0
hi.. i would be going taiwan next month.
would be taking TRA trains from TMS to other places..
like to check if they allow full sized luggages.. I have a 29" sam which i would like to bring for taiwan..
Would they be allowed onto the trains?
Thanks!
fireworks79
Thanks!
yes.......
fireworks79
thanks alot bro!
your reply is very reassuring!
:love:
dun happy to early. the aisle oso not veri wide u might haf little problems dragging the luggage. but then everyone did the same so no big deal if u happen to b blocking some1 way
calkel20
But with such huge lugguage, most will take HSR than TRA. As TRA may not have enough storage for your barang².
So which other locations are you going? If there is HSR stopping there, you may want to consider that option.
Kc0
hi, im going to hualien.. seems like only TRA goes there..
is there other mode of transport to go from Taipei to hualien?
Thanks.
fireworks79
Thanks.
take bus or cab or drive ur own but apparently no1 do tat. hence TRA is ur only choice.
however if u managed to take the taroko express, den the aisle n seat is more bigger.
Kc0
taroko sold out for my timing :(
no wonder they are more hot..
Kc0
hi bro, would this type of train be better in terms of space then a normal one?
"Run Everyday.Accessible Car.Bicycle bag available."
tang_tang
Advice on Taiwan TRA
Hi
I need to travel from Taitung station--> Hualien station--> Taichung station taking Puyuma Train. Then from Miaoli (Tongxiao Station) to Taipei station taking Tze Chiang Limited Express Train.
Does anyone knows all this train station have elevator or escalator? As i am travelling with 2 kids (3 and 6 years old) and will be carrying 2 big 31" luggage. Will lugging up and down be a problem for me? Is there spaces on the TRA trains for us to put large luggages for the above trains?
Thank you in advance.
calkel20
Hi
Can lug up n down.
Taitung and hualien have escalators.
Tongxiao should have it too.
wenguang
i tried to travel on TRA with my 28" luggage. My luggage too heavy to carry up overhead, in the end i just place it at my leg space.
calkel20
Any storage area that i can put the big luggage or i have to carry up and put at overhead storage in the train?
Usually big luggage like 29" will be where your legs area are.
If on HSR, yes, front and last seat back.
If smaller, can put on top, best.
