Apple TV 4
shawn_sboi
I didn't need to login iTunes account or download any apps. Set to US location, restart ATV3 and all there.
It's 2 different OS. Apple TV 4 is using TvOS hence those apps that you said had to be installed as the Developers of those apps like Netflix and etc could do updates to fix bug.
shawn_sboi
Just received the TestFlight email. Will test it out tonight :D
It's good. But metadata fetching problem. The rest is amazing. DTS, SRT and all.
Ian
1) Set it up on your router
2) make a vpn hotspot through your computer
Bro,
Just subscribed SmartDNS add-on to my current VPN for a small fee.
Hopefully it works else got to resort to the above.
oric1
Nice, can't wait to test it out this evening. I'm sure others would have reported the metadata fetching problem by now :)
elimmel
Thanks for enlightening me. If I'm on MR fibre, no issues with Netflix on ATV4 right?
Ian
There is an update of Firmware:
From tvOS 9.0 (13T396) to 9.0.1 (13T402)
falseflush
Just wondering. For those that use Netflix on the Apple TV, do you use your US or SG iTunes account? I'm referring to after you have set up Netflix and all, not before in order to download it.
I'm currently deciding between the two as there are pros and cons. Using SG account allows me to continue updating apps other than Netflix and purchase apps using my credit card (plus use Apple Music). On the other hand, using US account allows me to continue updating Netflix and most importantly, use Siri.
Of course, there is always the option of switching back and forth between the two, but that's terribly inconvenient as I would have to keep switching DNS (typing on the new remote isn't exactly a breeze).
icyflame
Switching accounts is very easy in the new Apple tv.
Anyway when I had netflix previously, I was using netflix on my iPhone but using my sg account.
No issues
D-Wade
Starhub GO
does anyone got info on Starhub Go App to have an apple tv 4 version app?
Ian
also singtel mio tv app..
does it have a appletv app?
Never tried searching since my region is set as US.
But Airplay Mirroring via my iPhone works fine.
Tested today and very happy it works and finally can watch soccer in the comfort of my bedroom since my MIO TV STB is at my living room.
Ian
referring to the airplay feature? if it is, then singtel tv go app is compatible.
Yeah Bro. Happy with my ATV 4 purchased.
But unhappy that MIO TV GO would start charging starting 1st Jan 2016.
sohbengkuan
The future of TV is apps.
So it's a matter of time that all the TV app such as StarHub Go and MIO TV Go and Toggle will appear in TVos App Store.
I believe
