Chromecast? Or 'Anycast'?
wickedpork
Hi
I'm trying to connect my tablet (the old Samsung Note 10.1) to my bigger LG TV.
I usually stream shows from China sites such as LeTV, Funshion.. etc on my tablet. Can I know if Chromecast works with such sites? Have been searching online but can't find a definite answer..
I think there are also some imitation China 'Chromecast' that promises to stream from such sites. . such as 'Anycast', etc.? Is this advisable?
I saw a lot of people disposing of their Chromecast here though.
Any advice appreciated. thank you in advance.
Ohayo!
Are you talking about screen mirroring? In that case, you have to check whether you tablet support it with your TV.
I bought those china made "chromecast" which simply mirrors what you see on your tablet onto the TV. It gets the job done. I don't own a chromecast so cant help you there.
yusoffb01
Latest Chromecast app support screen mirroring. Get it if price is $35
Alternatively buy ezcast from shopee app $11 before discounts
Both gets job done
If ur Samsung note support mhl, just buy $7 mhl to HDMI cable
MoneyFace =p
Shopee got their EzCast chromecast clone that seemed to work better than the original Google innovation lol...
wickedpork
hi
hi!
Thanks for all your advice.. My tablet does not support MHL too bad. It's the first generation Samsung Tablet Note 10.1.
Thanks for the recommendation on Ezycast.. How do I check whether my tablet is compatible with EzyCast? is EzyCast easy to set up? lol
Sorry noob .. basically my objective is just want to watch these dramas from China websites on my bigger LCD TV .. and not have to watch on small tablet... not sure whether this is called 'screen mirroring'..
Dr.Vijay
Administrator
Administrator
Shouldn't be an issue - just try downloading the Chromecast app.
If you can install it, that means it's compatible.
It uses Wi-Fi to establish the connectivity and the rest is handled by the app and the dongle plugged to the TV.
You can refer to our early review for a good idea:-
http://www.hardwarezone.com.sg/review-google-chromecast-tiny-affordable-hdmi-media-streaming-dongle
hi!
Koenig168
hi!
Actually, it does. You need the Samsung 30-pin MHL adapter for tablets. It's discontinued so may be hard to find.
ET_phonehome
i've got a set i bought from amazon a while back. is there any comparability issues using it? will it limit the contents?
FinalTidus
Anyway sorry TS but will OT from your thread as I just got my Chromecast last week so I like to give my humble opinions.
I got my Chromecast primarily for ONLY watching Youtube and for mirroring my smartphone on my 2nd PC monitor Dell U2410.
After setting up and updating the Chromecast and installing the Chromecast app, everything went well.
However my old Samsung Galaxy Note couldn't screen mirror to the monitor even when my phone has the latest Android 5.1.1 Lollipop. A bit strange. But my LG G pro 2 can mirror it perfectly. :(
All in all, it's a decent smart tv dongle.
Just one irritating problem I face. I cannot disable the image wallpaper backdrop that keeps downloading in the background even when it is not casting anything. I have to physically disconnect the USB cable to turn it off completely.
Just my comments.
yusoffb01
My experience is opposite of the person above. I bought ezcast because its 1/3 the price of chromecast.
Using the ezcast app, it has its own version of DLNA, where you send file to the device and the device decodes it. Most video files play fine like yify encodes with subtitles. Quality is as good as playing on your phone. However some high quality bluray rips cannot play
It has shortcut to your phone's own DLNA app if you do not want to use the proprietory one
It supports youtube like chromecast, but the quality is like 360p
The best function is the EzMirror ie Miracast. when u press this, device enters into wireless display mode, and you need to go to android wireless display settings to connect. Functions exactly like chromecast. There wont be any dropped frames if your phone is within the line of sight of the dongle.
Wireless mirroring works on my zenfone 2. But didnt work on samsung note 2014. i get hardware error. Both use lollipop 5.1.1
If u can afford it, go for chromecast, there are more apps for windows, android and chromeos that supports it
daniel_83
pricing should not be an issue for chromecast
Adix selling $25 for export sets
carousell got tons of people selling $30 onwards for brand new singtel sets (free from buying galaxy something phones)
wickedpork
I have one question Daniel. Chromecast --> can I watch dramas from those China websites?
Price is no issue.. just hate it when after buying i cannot use.
Thanks!
in short
Chromecast can do everything ezycast can do, but better and more.
Allanlee82
Thanks!
can if u download them to your tablet beforehand and mirror it to your tv.
Chromecast/ezycast uses your tablet wireless connection to link with the tv, so there will be no internet connection on your tablet anymore, unless you use the sim card connection to stream.
correct me if wrong, so the best for you is to purchase a tv box or mhl to the tv
daniel_83
Thanks!
u can only MIRROR to your TV wirelessly
so an Android TV dongle or MHL cable are the other solutions u can go for.
