17" tyres
koolaid
as long as your tire is popular size then it's cheaper nowadays
kim hoe so far so good. can go try .. go find alex
yes, already called them. their prices are very reasonable, almost comparable to the prices in msia. will most likely make a trip there next week.
camelsback
need to change mine soon too. what is a quiet and long lasting tire? ps3 and csc botak very fast leh.
St00ky
the prices of tires at tyrequeen should be on the high side i think... all cos they need to pay that lady in ugly pink hair some advertisement fee, so they need to mark up more... :(
tyrequeen close down liao leh :(
winorlose
i think 19 and 20" are very nice too, esp on sports cars and some 3.0 sedans like bmw or merc. imagine a civic or altis on 20" rims... :s13::s13::s13:
and i think the tires to go with these rims are not gonna be cheap too...
Some pple install 18" on honda vezel ok!
furryballs
Which one is kim hoe? Google shows 2 diff webby
http://kimhoeco.com
http://www.kimhoetyre.com
tankgunner
Mentor
btw i was with a friend at his mechanic last week and we met a guy who distributes a brand of engine oil called ROAR. lol... i know some of you are probably laughing at that name... he claims that his oil can go for 20k km. even showed us so many photos of super cars using his oil.
any tried it before? did your engine ROAR after that?
what is the price for 5L?
koolaid
good question... so far i have only used conti and michelin... so issues... my friend told me to try toyo cos they are japan. then another guy told me pirelli and bridegstone is also very good... wa, so many choices man...
sky00sky
By the way for those vehicle with tire pressure sensor
Change rims and tires at those work shop should be no issue correct ?
seowbin
Y so cheap for 18"? What size? I changed Michelin PSS 18" 245/45/18 @ 300 each including installation @ top93
what car you driving? why so huge
225 40 18 now 206 nia :s34:
last time used to be 25x, last week like 200?
