17" tyres
furryballs
My car using abs sensor as tpms... so far never trigger before coz i pump every mth
fartking
Normal tyres will stop losing pressure around 210+- unless damage or leaking. 1 month once ok lah, I go round every morning.:D
Zze121
Must see, same model tyre can be from Vietnam or Korea, there is price diff on both.
CCCustom
My opinion is that CSC5 is one notch above PS3 > the Goodyear F1.
So unless you can get PS3 or the F1A2 at a price cheaper than $160 as mentioned above, the CSC5 is a shoo-in.
And added-bonus, CSC5 with the best performance is probably also the quietest.
As I've mentioned in my previous post in this thread, using PS3 as a measuring stick for grip-to-noise, nothing in the market has better grip and lower noise, and most definitely not CSC5 ;)
Hankook Ventus S1 evo 2 is good quiet and comfortable tyres.
Above average in every count, but never tops in any.
I will get them for short-term use if they cost <$140 @ 17"
Hankook Ventus V12 evo2 is supposed to be their flagship performer.
Never tried it before, not easy to find the correct sizes in SG. And even if found, probably "not fresh" since they are not as popular as the other brands.
S1 Evo is higher-end than V12 ;) And it's not that they are not "popular", it's just that they are only sold at SHH outlets.
Savantrainmaker
Hahaha, really?
Both your narration so seemed to have been tossed up.....
yanbros
Anyone using yokohama v551? It's a quiet tire but lose out on wet grip when compared to ps3?
