Best VPN provider (In your opinion)? (Strictly no referral allowed)
oric1
Thanks much! Yeah, that looks good.
I've signed up for a unotelly trial, and that seems to unblock china content too. I wonder which would be better.
If Unotelly works for you then stay put if it's cheaper :)
moozmoow
just wanna thank you guys for updating this thread, didnt realise astrill had promo till today.
Sensational
So which one did you signed up? Frost or Astrill?
i haven't signed up anything yet. most BF sales are until 1 or 2 Dec anyway.
that is why I am asking the pros here for recommendations man. still not sure on which vpn to sign up.
PS. I tried unotelly also and it seems pretty good for loading content! But then its not really a VPN right? For bukit timah and all how?
testerjp
Which service is fast and can be used on chromebook with access to china sites?
musicalcharades
Hi guys!
Really new to this VPN thing.
Basically looking for a provider that would enable server to switch to China(youku etc) and US (for netflix).
What would be your recommendations? Thank you :>
The_King
Hi guys!
for me using astrill using stealth work sometime sometime
try looking at unotelly and check does it have the websites you wanted
oric1
Anyone know how the astrill vpn sharing works?
VPN Sharing add-on
Share your computer VPN connection with all your devices
Summary
You can enable VPN Sharing from Astrill application and share either OpenWeb or OpenVPN/StealthVPN connection, and then simply adjust network connection settings on your devices to utilize your computer VPN connection. VPN Sharing addon is affordable, and you only need a computer with Windows, Mac OS X or Linux operating system to use this addon.
There is no limit of how many devices you can connect with VPN Sharing. However a typical modem/router will allow you to connect up to 254 devices.
Share OpenVPN or StealthVPN connection from your PC with other devices (no special hardware or router needed). You just share VPN connection from your Windows, Mac or Linux PC at US$1 per month.
hnzfaz
May I ask if it's possible to have 2 vpn clients installed on a pc? I'm already on astrill. If I want to install vpn from another vpn provider, do I need to uninstall astrill's client first?
I tried to have 2 clients on my pc once, but there seemed to be conflicts even though I didn't turn both on at the same time. I'm wondering if it's the same in every case, or just that particular 2 clients.
testerjp
Just connect to Astril trial to try watch TVB dramas.
In the end, there's no contents or websites to stream the latest dramas at all.
oric1
Which sites are you watching? Let me see if I'm able to stream it.
testerjp
I think can stream, the problem is don't have content.
Example, i can only find two TVB drama under letv with HK and 2015 filter
Looking for the latest ones
oric1
I don't have problem and able to see everything.
LETV_zpsxwmi4jxq.png~original
