hi GX. will u be considering on bringing in the bigsexyhair brand ??Lol. I used the big sexy time gel. It doesn't stiffen the hair leh. Gives a considerable amount of volume too.
So myth busted Haha.
hi GX. will u be considering on bringing in the bigsexyhair brand ??![]()
Yes, but your hair is going to be very stiff to run fingers through though.Guys, if i use dry shampoo+salt, will get the texturised effect bo?
Hi anyone can recommend a good pomade for combing my hair backwards? Used blind barber 90 previously but it's not holding my hair well. Tia!
Please show a picture. I suspect its your haircut, not your product. Blind Barber is *******king strong.Hi anyone can recommend a good pomade for combing my hair backwards? Used blind barber 90 previously but it's not holding my hair well. Tia!
I would beg to differ based on my personal experience.Please show a picture. I suspect its your haircut, not your product. Blind Barber is *******king strong.
Amazon bestCare to share a commercially available link?
Btw jh, using gel as prestyle lowers blow dry time. You're supposed to let the gel harden then break it apart. Normal gel can already. It wun feel heavy at all. Wax is nothing but gel+pomade. If you think gel so jialat warrants an essay, wax gg liao.
Sent from GAGT. I hope you too are using GAGT
Yes you are right. In fact, its what i mentioned earlier. Some products like big sexy hair volumizing gel, does not stiffen the hair as it contains aloe to soothe the hair. Quite a number of good reviews about it too but like always, not all will be suitable.![]()
Precisely the opposite. Gel should be used as a prestyler instead of main.Haha actually i am not against gel, just not the idea of gel for volumizing. Using gels as the main styler is alright for me. But something that i have to disagree with you will be the weight coz it feels heavy for me. A good thing abt gels is that it tends to tame frizzy hair, making one look neat.
depends, but that's the only volumising gel that i have used. It's less dry but it might be a little stiff but it holds out better.. lol. i tried and i wanna buy again but cannot liao. amazon don't ship them anymore
speaking of which, i will use tmr, see how it holds out on my longer hair now
Anyone try the ebl taste before? Like value only sia~~~
Shampoo sellers, got xmas promo a not? My vogne is finishing
btw the vogne shampoo, I'm still using it after 11 months. Left maybe 1/5. Am i using too little? Haha. cause the description says a bottle can last 1-2 months. But the amt that i am using, it foams enough for me to wash my hair. The conditioner, still 3/4 remaining after 11 mths. Seldom use it.
Ur hair jin long meh?
