[Official] Apple iPhone 6S/6S Plus Discussions
athenodorus
Hi all,
does anyone know the prices (range) for iP 6s/ 6s+ or where to buy Brand New local set for best deal currently? Not intending to get from Operators with recontracted line... TIA!
Go carousell try your luck?
gundam77
Thanks athenodorus for the reply & suggestion, however am looking to buy with official receipt fr claiming purposes...
Heard about a few shops or bros mentioned in HWZ with good reviews (Adix, Kasia, Mobile Square etc...) Anyone have prior experience buying iP6s from them? Comments welcomed, thanks.
athenodorus
Erm carousell will also have sellers that sell the set with official receipt. You just need to search for the right set.
coolninja02
Anyone's camera has the same problem?
Whenever i face my camera to the light, there will be this bright circle thing. Been having this issue since iphone 6 and now 6S..
Alpha85
Trying to restore from a previous backup, but my phone struck on the Updating iCloud Settings page for about 3 hours. Typically need how long ar?
KwayChup
Phone went berserk when I was powering on, screen flicker and fades to black,then restarted. But it's okay now... Hopefully it's not a sign of failure...
gkhchay
I restore from backup using iTunes - about 1 hr because I have over 200 apps. I'm on Singtel 1GB fiber.
Restoring backup from iCloud will take longer than iTunes - exactly how long will depend on your wifi downloading speed & how much you have in your backup.
kenchi
suggest backup to itunes and not to icloud
if want lesser issue and faster too
ahtancw
Mine is a blur mark on the TOP of the screen. Tried all software reset and does not work. Will be bringing down to A labs at ps
devilot4
New iphone user here, does anyone know if there is a way to defragment? I mean surely u will install some apps, find that they are not so useful or good or for whatever reason, then u delete them. As time goes on like that, surely the phone will slow down right? Seems like can't find a good app for this purpose in app store..
gardiboy
No such app or any need to defragment. The phone ises FLASH memory and not a mechanical hard drive. If you find the phone slowing down, just reboot it.
