If no garmin virb can use the software?Yup, added after I got home. Used the free Garmin VIRB edit software. Just have to merge the footage and .gpx navigation file together, then add the gauge overlay. Gotta press record and start both cam and Garmin unit at the same time, though.
rubbish, no one will give a **** on what you riding. $20k bike,$15 k wheelset, no one give a damn
usually they will admire those who are strong, even though they riding norm bike.
that's the reason nowadays i don't talk about technical stuff, waste of time.
Lone cyclist when fall down or car accident happen at night ...nobody to help![]()
Inform family members or ppl you stay with about where you cycling to and roughly how long you will take.Lone cyclist when fall down or car accident happen at night ...nobody to help![]()
Any man who cant afford to be in the same league, would have reacted the same way![]()
Hi,
My current tyre is 700Cx35, I have 2 questions.
1. Which tyre is more puncture resistance?
2. Can I change my current tyre from 700Cx35 to 700Cx40 without changing the rim?
Thanks in advance.
Regards
Chong
Hi,
Schwalbe Marathons are the gold standard when it comes to puncture resistance.
As Theo says, you have to see whether or not your forks have enough clearance for such wide tyres. Don't know why you need such wide tyres, though.
128km completed in 7.5 hours inclusive of 1hour meal and 8 water breaks on my Tern!
Oh ok got it. Thx!!!Yup, can use any cam footage with the VIRB Edit software. But you'll have to press Start (on your Garmin Edge, for example) and Record on your cam at the same time, so that the footage and navigation etc data will be in sync.
Same type of tire? I have been cycling about 200-400km a week for the past 7-8 years and I only have gotten one puncture during a ride. Or maybe I am just lucky.wide tires wun puncture more easily?
i used to ride on the stock 35C, every mth puncture until bleed $$ gao gao
now on 700 * 28c no puncture for 1year liao![]()
