lxb_70
- May 3, 2006
if i turn off this optimising button, will it help to save battery?
Sent from my ah ma phone using GAGT
that time i bring my fren to buy his note 3 at j2 mobile... she diam diam show her longkang...Now Jover Chew going jail you got chance liao right lol![]()
LOL. its supposed to be turned on to save your battery...
maybe you can try to experience it a bit turning it off..![]()
that time i bring my fren to buy his note 3 at j2 mobile... she diam diam show her longkang...![]()
Size bigger got more "things" to update? Coz sometimes i saw ota very small file size while thru sammy is huge... hmm
Sent from the dark side of the moon using GAGT
so, can say the smart switch is "better" lor?OTA only downloads the new stuff (sort of like new add-on to the existing firmware in the phone and refresh the firmware) while Smart Switch downloads the entire new firmware and overwrites the existing firmware. Hence, the huge difference in file size.
seems to make some soft buzzing noise. is this normal ?
ha ok thanks. cuz i find that it doesn't really seem to be helping with my battery.
Oh thanksboth the same. see which one u want nia.
OTA is slow but fuss free. but occasionally will cock up. smart switch is faster to download but a bit mafan as they will need to download the pack, then verify, then push to phone etc..
my fast charging not always working.
unplug/plug the cable still the same
but ive the habit of plugging in and out to check and see if fast charge enable but i scared the battery gonna spoilt fast![]()
Oh...i see... another post about the charging problem...
This was discussed a few days ago, and repeated a few weeks ago, and repeated 2 months ago (you get the point)
Just change another cable, don't use the cable provided in the box and the phone will fast charge all the time.
Plugging in and out will spoil the battery faster.
Imagine you are the battery. When you shove the USB port into the charging port, electricity flows to the battery. The battery becomes shiok. Then, you withdraw from the charging port. No electricity, no shiok. Then you shove in again, battery shiok. Then withdraw, no shiok. The battery will become gila very quickly from the repeated quick burst of shiokness to no shiokness.
Battery prefer to be shiok for a longer period of time. But too long shiok everyday is bad for health. Quickie is preferred. So, let the battery have quickie almost everyday and on weekends, let it enjoy the full course of shiokness. By the way, how long is the quickie depends on the mood of the battery. 25%? 73%? 55%? Of course, when the battery is low on juice, a longer quickie is required to increase the juice. When the juice is not very low (still quite juicy), a very quick quickie is needed.
