The Spectacles Thread. - Part 2
jonleelk
Hi both frame are same just different color
Then different from my previous experience. I switched from full rim to rimless. As the lens edges are exposed, got more light reflection, and I felt giddy after wearing for a while (closest normal people get to feel paparazzi flashlights non-stop). :s22:
A few days later, got used to it.
bjornng
anyone knows the best place to get a pair of rayban warfarer's polarized? :) by best, i mean bang for buck :D
GPGT.org
Hi GPGT bro can check if your new lens degree and old lens degree is same or different? My new lens degree is the same i went to check with optic shop they say by right same degree shouldnt feel giddy one. Anw I tried a few days can't take it, maybe i try a few more days and see how..
totally the same degree... no change :s12::s12:
ericsoon72
Want to get advice on getting contact lenses...
I have the following eyeglass prescription:
Right: -3.00 (Sph) -0.5 (Cyl) 165 (Axis)
Left: -2.75 (Sph) -0.5 (Cyl) 180 (Axis)
What should my contact lens prescription be?
Thanks!
TUV2008
Just made this pair in Tokyo that costs me only $57 with prescribed lens done in 30 min. I top up another $57 for 1.6 index, so at $114 in total the price and speed of service is unbelievable more attractive than any shop in Singapore, even their progressive is only $100 more, can't understand why our spec here so expensive???
Sent from Xiaomi MI 3W using GAGT
dsclaymr
Starck Biozero
Hi ppl,
Been looking to get a pair of the stack biozero, was quoted ~800 for the frame. Would like to ask is that too much? And do you guys know a reputable shop that carries a wide range of Starck frames?
TIA!
Seannie
Hi ppl,
TIA!
Yes too much.
Seannie
Thanks Seannie. Do you know if KS carries Starck? And what would be a reasonable price?
I googled abit a few months back and saw it for about USD400 online. But I forgot which website it is anymore.
~600 should be more reasonable. What is KS. If can get online then good for u lor.
evets
Hi ppl,
TIA!
i got my first pair of Starck at one of the optical shop at Nex, tried going to other shops hoping to get a better deal, end up still went back to the first shop cause others do not carry that model.
I got mine 2nd pair at Paris Miki, the range are limited though. Wanted a mykita but still end up with a starck. :s13:
