- Aug 9, 2011
If it was a direct lightning strike extensive damages would be obvious. This scenario is unlikely because all our buildings are protected against direct strike. [Latest building codes also specify protection against lightning surge]
It would be difficult, if not impossible, to proof that the tv failed because of lightning surge. There won't be tell tale sign unless you inform the Service Centre.
Since your set is still under warranty, send it to Bedok. It may be far away unless you live nearby. But I believe they will honour the warranty. In any case they will inform you of the repair cost for your agreement, if charged, before they proceed. That's my experience with Panasonic products. Out of warranty repairs are usually slightly less than half of cost of products.
Yes it would be difficult to tell and may be it is not lightning surge.
