Cashflow202
- Feb 24, 2012
Why do u think it will head lower?
The 3 big fears, oil, china, rate hikes
All already priced into current market
If market goes lower, more likely is due to new factors not seen yet ba
The only serious TA guy (after FCS) i have seen here, wonder y TA is so unpopular.
Wedge is the cone like shape u see on the chart
Falling is that its pointing down
Down trend
The narrow tip of the cone must see it come out higher or lower
A Falling Wedge looks like an elongated triangle that slopes downwards with the price spiralling lower between two converging trendlines. It is usually found in uptrends as a continuation pattern that slopes agains the prevailing trend. Sometimes, the falling wedge may materialize at the end of a prolonged downtrend where it can act as a reversal pattern.Volume decreases during the formation of the wedge and should expand on the breakout.
Anyone knows why bond etf a35 climbing? I tot rate up bond demand decreases one![]()
Look at the bid ask spread
Its so wide
Last done higher than current ask
falling wedge spotted in sti
can breakout or not for year end rally?
But why would a higher ask result in higher prices when supply > demand?
Shouldn't it go down cause no one wants to buy the stock yet ( as shown by wide gap)
Sinkie SIC more TA leh. THANK YOU
Last time old thread at EDMW always you and milo SIC TA![]()
Hopefully got Christmas rally. Can offload bank stocks for quick kopi money.
Noob qn: if my order is partially filled, I end up with odd lots?
).No. Only if you use the unit shares market on L&T, CIMB or POEMs. By default trading is done on the normal market with board lots. Partial fill for board lots still OK (depending on the purpose of your transaction la, that is.).
