The Wallet Thread
Henabi
i didnt do anything to condition.
do we need to condition it actually?
No need to condition. Leebee canvas iirc already reinforced to be very tough...
I have a friend who has a speedy as a daily bag. Use for 10 yrs liao...till now the bag material still in fantastic condition...barring minor scratches...
stylux
hi guys, looking for mens short zipper wallet with coin compartment inside. any gd recommendation? cant seem to find what i want. closest i get is from Shinola Robinson horween leather but no coin compartment also no hidden slot.
maybe cdg wallet u can try..
hwaa
Bought from SG?!?!
If so... Steady. Well within my budget
yup bought from taka. but when i was there this is the last piece... dont know they still have anot.
perhaps can check from ion also.
hwaa
guhan05
Anyone know which burberry outlet has good variety of men's wallet
Paragon? Ion?? MBS?
darkdevil
need some recommendation from you guys. been thinking to get myself a new wallet for the new year (old wallet is coming to an age)
thinking of getting a customized wallet (by OGL) or perhaps a Mont Blanc wallet which is much more expensive.
fade_white
What do u guys think of this wallet? It's a card wallet size but has compartment for bills.
http://gnomenbow.com/products/pine-card-wallet-oxblood
Been using the LV card holder like hwaa posted above for quite some time, older design but same card slots. Drawback is no proper slot for notes.
If this one no good, any recommendations for wallets that are like this? Small size but got proper compartment for notes.
lucied
I went to the store to check out their lincoln bifold wallets. Leather is really thin and cloth separator will fail first. Thread seems okay and edges are burnished. Would only recommend if you want something slim and not BIFL.
darthsid11111
OGL all the way. You pay for better leather as opposed to branding.
Sent from the exploded Death Star using GAGT
fade_white
thanks bro...have u come across any other brand that makes something similar to that in function and size but made from better leather?
