Rodon_Tan
- Dec 11, 2012
hi guys, i can't make any calls or send sms using my normal pre-paid SIM card. it used to work in the past. the data plan sim card is working, however (this means, i can surf web and whatsapp, but cannot make calls or sms).
when i try to even use the check enquiry of balance in prepaid card, it says "request failed", meaning it can't even dial to Starhub. any advice?
i'm using the HK version where it has 2 SIM card slot btw.
i run some tests and it can detect both SIM cards, but not sure why calls and sms doesn't work.
