Damn, that is nice. Is that the octagon?
Can't really tell from the blur pic
my wife took a video of her ring with her friends... One is a super ideal cut, one Solasfera and the other is only an Ideal Cut from other chain store. Can you tell which is which
If I'm reading it correctly, there's quite a huge feather at the side of the diamond. This means that it'll be more prone to chipping or cracking over the years. Do take note of that and be more careful when wearing the ring![]()
Yep noticed that feather as well. From what I can see it is not on the surface nor exactly near the girdle. But still have to be careful about it.
Thanks.
Bottom ---> Solasfera
Right ---> super ideal cut
Left ---> ideal cut
can tell that the diamond looks more sparkly!
Sweee~
The one on the right and bottom look very blingbling!
Im guessing below Solasfera and right side Super Ideal?
The bad one can tell is the left one la hahahha![]()
Top left one is the Ideal Cut? There is really a different in terms of the shine between the top left vs the other 2. Make me think of my Octagon vs my old diamond![]()
Bottom one is definitely the most sparkliest so I'm gonna assume that's the Solasfera.
Right one has substantial sparkles but still not as much as the bottom one. This one should be the Super ideal cut?
Left one one loses out to the other 2, so I take that as the Ideal cut.
That's my final answer
Any prize for the correct answer?? haha
You mind sharing the specs?
All of you are right!! hahhaa. I guess its really obvious then.
The right one is mine, Jp's Super ideal cut. Its a 0.5ct f vs1. The bottom one is my wife's boss's Solasfera. The one of the left is an Ideal cut from a chain store..
Funny thing is the one of the left is of a very high specs! Its a D VVS1. But I guess the cut not so good so make the diamond appear overall darker. And her diamond ring actually cost more than ours.
best thing now is... My wife is asking to upgrade to Solasfera! hais..![]()
May I know the size of the Solasfera as well? It really sparkles more than the rest. But i feel that the one I got for my FW doesn't sparkles as much. Not sure if i gotten a size that is too small for the Solasfera cut to perform.
thanks for the sharing
really can see the sparks!
Cert no 2197546378.
Dont know why but the diamond doesnt look very bling bling.
Anyone can enlighten if its good?
