Netflix SG
tk
Hopefully Starhub and M1 will also follow the same so that user can have a better connection to Netflix. If use their STB is only HD video and no UHD?
if the other ISP can do the same then it's not 'exclusive' partnership with Singtel liao..
Henry Ng
May be u are right however using STB will be HD only as their box is HD. Also can not 4 screens viewing for big family. May be other isp can have other arrangement with Netflix later.
WestGuy
Netflix signed exclusive partnership with Singtel.
So apparently we should be able to watch Netflix through the Singteltv box, but their box is only capable of 720p/1080i. Urgh, i might as well watch through the app on my TV which can get me 4K
pustefix
Hulu has been doing this VPN block since April 2014, if you search on the net, you can still find ways to get around it, so I don't think you need to worry too much.
djchris
Even if VPN IP addresses got blocked, VPN companies will work out new ways or get new ip addresses to not get blocked after a while. Otherwise how to make money?
VPN companies won't roll over and die.
euko82
Means what???
