MoneyFace =p
- Dec 17, 2010
Thanks for giving me a recommendation. I didn't consider Gigabyte initially is because I'm sick of looking at my AMD gigabyte motherboard for the past 6 years lol.
This motherboard you recommended is indeed interesting. I did a search. http://www.gigabyte.sg/products/product-page.aspx?pid=5491#sp
Let's see.
It's micro ATX. - ok, can consider though I would prefer a mini ITX.
M2 support - didn't know B series support M2. Ok good. But can a Samsung 950 Pro fit in ? I read one of the MSI motherboards M2 only allow 60mm while Samsung 950 Pro needs 80mm clearance while another Asus user cant detect his Samsung 950 Pro after plugging into his Asus mobo.
Skylake i7 support - ok, can plug in an intel i7 here.
4 DDR4 DIMM slots (support to 2133Mhz) - I read that DDR4 2400 is recommended as minimum to fight against DDR3 so how future proof is 2133Mhz?
AMD Crossfire support - lol..I just got an Nvidia GTX 970 even though I'm an AMD fanboy...so...haha...this feature doesn't apply unless I sell my GTX 970 later on and get two AMD Polaris cards and crossfire them to blow Nvidia out of the water lol
Overclocking - since its a B series chipset, I assume overclocking does not apply here?
If you prefer miniITX you can forget about doing any crossfire or SLI already...
Yes you can see there are 3 mount holes indicating their length number on the motherboard itself in the middle.
And you should ditch Core i7 la. See the table in the link on my previous post.
Even if you wish to do multi-GPU setup, mATX isn't favourable either since both cards will be installed on 1st and 3rd slot, leaving little to no gap in between, causing 1st GPU's temp to swell up high and fast.
And lastly, RAM speed doesn't really matters since DDR3. Read this:
http://www.legitreviews.com/ddr4-me...nding-the-best-ddr4-memory-kit-speed_170340/5
