Yureak
Hi all,
Recently had a Control4 system installed in my place. Really revolutionised our lifestyle and everything from Climate Control to Blinds and Lights can now be controlled via Ipad or Iphone.
Anyone got questions can ask here
:s34:
one this good
is nice to program all your home application on auto mode
like si be high tech.
but bad point ..if either of them cannot work...it cost a lot to repair, maintenance it mah?
Yureak
:s34:
one this good
If you go with high end brands, you can't program yourself. Dealer will do everything.
Additionally dealer dont even need to be on-site, can test and resolve issues remotely.
Go for brands like Control4, Crestron and AMX but expect to pay around 10k-20k or more depending on how big your house is and how elaborate your system is.
poly use Creston lor ...control the audio visual stuffs..
but actually also got faults. The touch panel after certain normal usage ....will not be sensitive...even is , the connection sometime don't work well.
PlayDough
What kinda house you live first? Automated and all high tech but is HDB. What's the point?
Yureak
Thats why i dont go with crestron. Additionally, the way u control is also very important.
For example IR control has no feedback. Meaning if u click on it transmit on but the system cant tell if its already on.
Whereas for IP control, zigbee or zwave u can
Yureak
can share what are the use cases of home automation in your home?
Scenes. Eg wake up in morning blinds will come down to block the sun. Lights can come on gradually. A/c can turn off. Radio will switch to your preferred channel
Or goodnight Scene
Following a short delay, all devices and lights will turn off
:s13:
that why government spend " a lot " lor
Buy expensive one ironically can't work well...
buy cheap ones ..ironically also can't
Simply because the purchaser , manager never do homework well thus waste a lot public funds...zzzz
DarthKool
Or goodnight Scene
the blinds come down based on light sensor or it connects to internet to check your area's sunrise time? :o
Yureak
For mine its timing but light sensor is no issue too. Can add on for $100-200. Theres also a light sensor that adjusts blinds position according to light direction and intensity.
If u live in a 24/7 aircon house, the thermostat can use this change in blinds to help maintain comfortable house temp
Yureak
:s13:
Well u have to do ur own research
Jay Bee
my house automation only 1 line of code.
on aircon;
no aircon my parents will die :s22::s22:
heng oil price drop, now only 2cents per kwh
Yureak
on aircon;
A/C temp is impt too. Cant blow the same temp at night and at day
All these are connect via IR so all what RFD..what ever....
each devices have a small IR stick on it.
I not sure how TS works
this is what i used to play before and noticed....
anyway Home automation is like " additional bonus to enhance your house " lor....
some people spend a lot on designing their home ...
got spare cash also add in " these home automation stuffs "
asiafrenz
Or goodnight Scene
so there is some sensor that sense for sunlight and bring down blind automatically? how does it know how much sunlight is too bright or is the right amount of brightness that you dont like?
how does it decide how dark then it turn on light by how much?
how does it decide when there is someone in the room and when to turn on and off by itself?
how does it decide when you are in the house and turn on the radio to the right channel for you?
Can it sense for rain and close the window and sliding door at the balcony for you?
