Yureak
All these are connect via IR so all what RFD..what ever....
each devices have a small IR stick on it.
I not sure how TS works
this is what i used to play before and noticed....
anyway Home automation is like " additional bonus to enhance your house " lor....
some people spend a lot on designing their home ...
got spare cash also add in " these home automation stuffs "
I avoid IR as much as possible. Mine is mostly zigbee or zwave, ip control or rf.
For blinds Zigbee or RF works
Starbutt
Has your electricity bill increased with all these 'automation'?
I am skeptical about such smart home gadgets unless you are living in a sprawling villa with so many rooms that will warrant such frills.
Otherwise if it's just a apartment, condo or hdb is just plain overkill.
Sent from Xiaomi MI 4I using GAGT
Yureak
so there is some sensor that sense for sunlight and bring down blind automatically? how does it know how much sunlight is too bright or is the right amount of brightness that you dont like?
how does it decide how dark then it turn on light by how much?
how does it decide when there is someone in the room and when to turn on and off by itself?
how does it decide when you are in the house and turn on the radio to the right channel for you?
Can it sense for rain and close the window and sliding door at the balcony for you?
Rgding blinds, dealer can set threshold.
Regarding occupancy it'll sense if youre home through motion sensors. Additionaly yale real living locks can know who's home based on the rfid card key. So eg if u come home after work and like a certain lighting or tv channel it'll switch for u. If your wife is home it'll be another config.
Rain sensor is also available and yes can work with motorised doors (but ive never seen a motorised balcony door)
Well u have to do ur own research
Heng, I civil servant.
well....they don't do much in depth research one...=:p because jiak liao been daily and wayang..
The main issue is not research..because things how inside work is...they always want to use up all the funds given by MOE...so next financial year able to get new funds..
if never use up the funds will been ask etc
( irony right )
Not related to your thread..but as I work in stats boards , in the poly ...and since you mention about crestron this brand ...lol make me think of this
Yureak
For high end systems, the gadgets can't even be seen. It's all hidden and it's designed and programmed just for you so it fits into your life.
Electricity bill is about the same. Only some additional hardware to be powered eg controller, network switches and infrastructure etc
cuppa
10k? Resberry pi $25 also can do the job. Though accessories and option modules not included yet.
Yureak
( irony right )
I see. Personally i avoid crestron from experience using it prior. Control4 is a much better fit for me
cuppa
( irony right )
Every company is the same.
DarthKool
hmm was thinking too much then, thought got similar stuff like amazon echo, or a siri on steriods.
something like bring girl home, i say keyword followed by "jazz this place up", system turns multi color led lighting to pinkish and load up a jazz playlist from spotify...
and maybe auto turn on tv, connect to netflix and get 50 shades of grey :s13:
Yureak
Won't be seamless and bespoke. Look at this video
https://www.youtube.com/watch?v=ujX5MTYKLwM
Not on pc would be grateful if someone could help embed
Yureak
something like bring girl home, i say keyword and then jazz this place up, system turns multi color led lighting to pinkish and load up a jazz playlist from spotify...
Yes all of which u mentioned can be easily done lol
Starbutt
Add "block calls from wife" to task list. Hahahaha
DarthKool
will be fun to see how far this goes.. cant wait for my toilet to analyse my poop and urine and then plans the next day's meals :s13:
Yureak
Wow this one is a scene right out of the island.
Anyways maybe in 10-20yrs time
regarding that
also possible,
I not expert on these home automation stuffs but I find it is more on " COOL " part whereby people come to your house
lol you just clap your hands , lights either turn on or off...etc
A lot videos online got show case about Home automation ..
I feel western countries more into this ....for asian countries not much...
Anyway , I don't surprised next time our HDB home will include all these...
in fact , If i not wrong , HDB got experience on some HDB flats liao...
for example now corridor lights ..they using " sensor type " if no body walk the light will do slightly dim a bit...
when a person happen to walk pass or around ..the light will brighten up a bit ..after the person walk off ...the light go back dimmer a bit.
makav31i
TS you DIY the system or ask soneone to help install...I'm thinking of using zwave smart switch for my lighting or do you think using a smart bulb like the Phillips Hue is better as you won't need an electrician to lay the Earth wire for your lighting switch...
