Qoo10 Deals. (Strictly no referral link)
whatheheck
Now give qpoints very stingy. The events start in qsquare then link you to qtalk to do side quest then go back qsquare collect reward, then collate rewards get qpoints . Along the way, apps screw up them side quest incomplete = can't collect rewards. Can't code properly thrn don't interlink app quests mah
Sent from nowhere using GAGT
kandinsky
Yeah, not worth the effort for me. Can't be bothered, only doing daily attendance now.
whatheheck
My phone still cannot join the live forum. Got message that cannot create room.
Weird. Yours is android? I had same issue but it was fixed in an earlier update some days back. The newest one probably fixed the crash problem.
Ios still have the cannot join forum probably because the app update needed to be reviewed for approval by Apple first so kena stuck in the limbo currently bah? I can't be sure though
urutoraman
Have you try clicking the "Apply" to collect the banana without joining/chatting on live forum of the Day? Sometimes it works because of the bug.
whatheheck
where to grab the 300 points?
Really depends if you're comfortable with adding for the 300 qpoints
Lucky177
CNY $5 cart coupon. (Minimum spending $30) x 1
Edit: Someone already clicked and claimed. :)
shadow84
If anyone is comfortable in adding me as qfriend just for the qpoints, do PM me for the number.
